vtec solenoid diagram
Old Oct 2, 2002 | 08:45 AM
tunes12's Avatar
Default vtec solenoid diagram
Does anyone have a picture of all the parts that make up the vtec solenoid. My vtec doesn't work and I've done every possible test there is. Ecu is fine, no codes. I took off the valve cover and vtec solenoid and hooked up air pressure to the port near the vtec solenoid and noticed that the rocker arms do lock in place once there's pressure. So it seems that the vtec solenoid valve is not allowing pressure to build. I looks like there's something missing too. Any help would be great.
Thanks
Old Oct 2, 2002 | 10:37 AM
earl's Avatar
Default Re: vtec solenoid diagram (tunes12)
How do you know it's not engaging? Will not engage without temperature and oil pressure being read by the ecu.
Old Oct 2, 2002 | 11:49 AM
tunes12's Avatar
Default Re: vtec solenoid diagram (earl)
I've been driving the car for a couple of weeks without vtec, and decided to troubleshoot the problem, then I took the solenoid off.
Old Oct 2, 2002 | 04:11 PM
bruthaboost's Avatar
What kind of engine do you have. The b and d series have slightly different setups. I to am having vtec engagement problems and am not getting pressure to the solenoid. Am at my wits end. I'm about to just weld a 4an fitting to the oil passage and source the additional pressure from the oil pump directly via z10 adapter.
Old Oct 2, 2002 | 04:28 PM
earl's Avatar
So it did work at one time? Which motor?
Old Oct 2, 2002 | 04:36 PM
tunes12's Avatar
I have a b16a1 swapped into a 91 crx si. Today I swapped the vtec solenoid assembly from a b16a1 into 95 si with a b16a2 and and it worked fine. So i guess its not the solenoid assembly itself. I guess its more troubleshooting for me.
Old Oct 2, 2002 | 04:39 PM
tunes12's Avatar
I don't know if it ever worked. I assume it did at one point. I had the motor shipped from a company in montana, which got the motor from Japan. I've had the b16a1 swapped in for about 3 weeks now, and it hasn't worked yet
Old Oct 2, 2002 | 06:08 PM
earl's Avatar
Are you sure you are using a vtec ecu?
Old Oct 2, 2002 | 06:26 PM
splitime's Avatar
One common thing i hear people checking for is oil level. I've seen alot of recommendations to have your level at the max mark on the dipstick, not more because thats just more work for the engine. Also make sure the car is at operating temp so the oil flow/pressure is correct.
Old Oct 2, 2002 | 06:30 PM
Kamin's Avatar
https://honda-tech.com/zerothread?id=164863
good luck.
Old Oct 2, 2002 | 06:37 PM
earl's Avatar
Default Re: vtec solenoid diagram (KAMiN)
If this thread won't help you, nothing will
Old Oct 2, 2002 | 06:59 PM
It seems we have a similar problem. So I take it you went through the helms procedure for checking for oil pressure to the vtec solenoid?
Old Oct 2, 2002 | 07:35 PM
ImportRacing's Avatar
Default Re: vtec solenoid diagram (bruthaboost)
what was the oil prssure for the vtec solenoid. Might be your oil pump is worn out also. It can also be that your cat clogged and not letting the exhust flow out causing some back pressure. Check if the spring inside the vtec solenoid is moving freely. I had this problem also, My car would not engage vtec. I made a manual switch to test it out, by hooking a wire to the positvie terminal and than to the switch and from the switch another wire to the solenoid. The car would bog down or seem to redline. The rpm would move slowly once it hit vtec and stay in one place. I fixed it after someone told me it was my cat. I rmoved the cat and drove down the freeway and the vtec was working no more bogging down at vtec range.
[Modified by ImportRacing, 4:41 AM 10/3/2002]
Old Oct 3, 2002 | 10:34 AM
tunes12's Avatar
Default Re: vtec solenoid diagram (ImportRacing)
O.K. I'm going to try and answer everyone's response. I have a pr3 ecu, throwing no codes. Oil is full, and car up to tempurature.I did the wire test for the solenoid and it clicks. The speedometer works, and there's no dents in the oil pan.The entire solenoid assembly is good because I put it on another car, and vtec worked. I hooked up a mechanical oil pressure guage to the port on the head by the solenoid, drove the car and the guage reads about zero until I get to about 5000-6000 rpm and then it jumps up to about 75psi, which I believe is normal. The only thing I haven't done is swap the ecu for one that definetly works. But if it was the ecu, then why isn't there a code and why would the solenoid open up and allow the pressure to jump to 75psi. Also, can you have a bad vss and still have a working speedo? Thanks.
Old Oct 3, 2002 | 01:39 PM
If you're getting 75 psi over 5k rpms, then you should be getting vtec (anything over 57 psi is good). Your system is operating normally. How do you know you're not getting vtec?
Old Oct 4, 2002 | 05:38 AM
tunes12's Avatar
Actually, that's a good question. I'm going only by sound. I have a 95 civic si with a 99si b16a2, and when vtec engages on that car, it sounds much louder and much more radical. It's such a big difference that I figured that it's not possible for the b16a1 in the crx to be that much quieter. The only difference is that I have an aem short ram intake in the 95 si and I have a stock intake with no resonator on the crx. I think I'll try and put the aem short ram on the crx to see if I can hear it. Also, I'm expecting the crx to be a bit quicker than it seems right now.
Old Oct 4, 2002 | 08:11 PM
tunes12's Avatar
Is there a way to actually know for a fact that your vtec is working?
rumo1112
Jan 17, 2011 10:57 AM
krytoi
Aug 4, 2008 03:41 PM
s1ngle
May 6, 2005 06:50 PM
sharkcohen
Mar 11, 2005 07:55 AM
skrewdlude
Apr 19, 2002 09:03 PM
