Can I go off of any pinout chart for obd1 conversion
Old Jul 14, 2011 | 12:18 AM
ridegreen02's Avatar
Default Can I go off of any pinout chart for obd1 conversion
Just bought a p91 ecu for my 91 civic, im doing a z6 mini me swap and need to know if I can use any pinout chart from a obd1 ecu like a p28?
Old Jul 14, 2011 | 05:52 PM
Default Re: Can I go off of any pinout chart for obd1 conversion
No body knows this?
Old Jul 14, 2011 | 05:56 PM
crx_si-r's Avatar
this sounds like research you should have done prior to buying the P91 ecu. what is this ecu out of? which car and motor?
Old Jul 14, 2011 | 08:40 PM
I did do the research, the p91 came out of a jdm sohc vtec engine. There isnt much research to do on this ecu trust me ive looked a lot. All I wanna know is are all honda obd1 ecus hooked up the same since you have to switch connectors. If they are not pinned the same then if anyone has a pinout chart for a p91 that would be very helpful.
Old Jul 15, 2011 | 03:48 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
You didn't search too hard newb...
Originally Posted by eg6ajk
the p91 came on the JDM D16a sohc vtec (Civic Coupe in Japan), the only thing is that they almost all of the ecus are auto, but can be reprogramed just like any p28 (other then very few programs which look for barometric air pressure sensor which is found on the usdm ecus only)
Old Jul 19, 2011 | 12:52 PM
I did by the way. You see If you can find me one and then tell me I didnt look to hard.
Old Jul 19, 2011 | 01:05 PM
crx_si-r's Avatar
sounds like a lazy response.
Old Jul 19, 2011 | 01:06 PM
crx_si-r's Avatar
first off, is your car a DPFI model or MPFI model? this will play a big role in what you will have to do to get your car/motor running properly.
Old Jul 22, 2011 | 10:39 AM
Its MPFI
swordofdoom
Engine Management and Tuning
19
Jul 27, 2020 08:05 PM
jmayhem
Aug 11, 2013 07:51 PM
Jap_Spec_Imports
Aug 10, 2009 07:11 PM
Spracer03
Jan 22, 2008 08:16 AM
