dc2 ebrake cable not fitting on ej1
Old Jul 13, 2011 | 11:58 PM
Kyle905's Avatar
Default dc2 ebrake cable not fitting on ej1
anyone know how to get the dc2 ebrake cable to fit on an ej1? it seems to be coming up just a bit short certain way to route it?
Old Jul 14, 2011 | 12:00 PM
Kyle905's Avatar
Default Re: dc2 ebrake cable not fitting on ej1
bump need some help is there anyways i can run it and leave the drivers side unbolted?
Old Jul 14, 2011 | 01:43 PM
Ghetto Civic HX's Avatar
I love to drive
Did you read the FAQ at the top of the forum? In the brake section there's a huge writeup on brake swaps. I'm assuming that's why you're trying to put a DC ebrake cable on your Civic. That's where I found this:
E-brake
The emergency brake cables meant for a drum setup has a totally different end at the suspension part, so those for a drum are not the same as those for a caliper.
Ideally you want to use 99-00 Si e-brake cables, but those from a 94-01 Integra work, as I have them on my 96 Civic right now, just mess with the adjusting screw.
I hope that helps.
Old Jul 14, 2011 | 08:15 PM
Kyle905's Avatar
i had integra cables but theres absolutely no way it will work oh well ill find something else
flyinfree
Sep 9, 2011 08:55 AM
elnoyl
May 6, 2009 01:21 PM
ONEhaque
Nov 10, 2008 06:23 PM
01Ntegra
Aug 11, 2004 10:56 AM
