B16a2 Idle Problem - Too High
Old 07-14-2011, 04:49 PM
BlueSmartEm1's Avatar
Icon6 B16a2 Idle Problem - Too High
i have a b16a2 and my idle is to high.. how can i adjust it lower? and what RPM should it be always idling under? thanks!
Old 07-14-2011, 06:51 PM
Former User's Avatar
Default Re: Idle Problem - To High
More details are needed. CEL codes? Problem happened after some recent work? The normal idle is about 700 rpm. What is your idle speed?
Old 07-14-2011, 07:38 PM
my idle speed is 1400 or so. ive a chipped p72 with no check engine lights on.. but my problem is my idle wont go down. i tried to adjust it from the throttle but nothing made a difference..
Old 07-14-2011, 07:53 PM
Is the throttle cable adjust too tight? It should have about 1/2" of slack.
Is the throttle body dirty?
Stock B16a2? Do you have an FITV?
Does the CEL work?
Old 07-14-2011, 08:03 PM
throttle cable is good... throttle body looks pretty clean to me.. it is a stock b16a2 just with a password jdm intake and headers. how can i tell if i have an FITV? .. and yes CEL does work.
Old 07-14-2011, 08:10 PM
Stock B16a2 would not have a FITV. Can you kill the idling engine by covering the top of the TB with your hand? If you use your finger to block the hole inside the TB leading to the IACV, does the idle speed drop to normal or below? Does the same happen if you unplug the IACV?
Old 07-14-2011, 08:15 PM
i haven't tried that yet, but ill go now. ill be back in 15. thanks !!
Old 07-14-2011, 08:20 PM
Default Re: B16a2 Idle Problem - Too High
hey i just went to try that and right when i covered my hand on the TB it shuts down.
Old 07-14-2011, 08:21 PM
Noted. Now try the other tests.
Old 07-14-2011, 08:33 PM
hey i tried that. and all of a sudden my rpm dropt down ti 700-800 on idle..
Old 07-14-2011, 08:36 PM
1) Try cleaning the IACV.
2) Try to properly adjust the idle speed:
https://honda-tech.com/forums/showpo...8&postcount=12
3) Test the ECT sensor and the TPS.
Old 07-14-2011, 08:58 PM
what do u suggest i clean it with? i fix the idle speed. back to normal. . how would i test the ect sensor and the tps?
MastaFlyMason
05-05-2013 07:24 AM
dc2_916
03-10-2008 06:20 PM
ludedude808
10-18-2006 04:52 PM
Shorty C
05-17-2004 11:40 PM
sleepyhamsterlx
01-06-2004 07:30 PM
Quick Reply: B16a2 Idle Problem - Too High
