sway bar end link bushings - energy suspension
Hey guys,
I was wondering if anyone knows if Energy Suspension made polyurethane bushings (black ones) that go on the end of the 22mm USDM ITR rear sway bar (connects to end links). If so, could someone help me out with a manufacturer part #? I've been trying to find some and I'm not having any luck. I'm going to replace the d-link bushings with black ES poly ones and I figured I would put in the sway bar end link ones as well since I have to replace the end links too.
Thanks in advance!
Thanks in advance!
The Energy Suspension front swaybar endlinks were designed for use with the 22mm LS front swaybar. But I suppose you could just use half of the bushings and replace just the control arm side.
Thanks for pointing me to Hardrace. Definitely going to get their end links and trailing arm bushings.
I'm still looking for the sway bar end link bushings... The really small ones. If anyone knows if anyone makes them, please let me know! I have an extra set of Acura OEM ones I can toss in but if there are poly or harder ones I can put in for a little more strengthening, that'd be great!
Thanks in advance!
Thanks in advance!
TOO MUCH TORQUE
Suspension & Brakes
Aug 27, 2009 03:45 PM
