Over Heating EJ6 Hatchy AKA EK Hatchy
Old Jul 13, 2011 | 04:03 PM
Amed Irizarry's Avatar
Default Over Heating EJ6 Hatchy AKA EK Hatchy
Ok I Got A Brand New OEM Thermostat From Honda. And I Replaced It Last Week. And I Replaced The Fan Switch Even Tho It Was Working. And Today It Started Doing The Same **** Again. Still Over Heating. Now What I Don't Get Is If I Hold The Motor At 4k. The Thermostat Gauge Flyies Down Back To Normal. Could It Be That The WaterPump Is Going Bad???? And BTW The WaterPump Does Not Leak AnyThing...
Old Jul 13, 2011 | 04:30 PM
Default Re: Over Heating EJ6 Hatchy AKA EK Hatchy
SomeOne Out There????
Old Jul 13, 2011 | 04:31 PM
Jz6m's Avatar
i had the same problem turns out i had a bad fan motor relay, i recommend this video it has step by step instructions about what could be causing an overheat issue
http://www.youtube.com/watch?v=hUzOTnsWImI
Old Jul 13, 2011 | 04:40 PM
But The Thing Is That The Fan Stays Running But The Car Is Still Over Heating.
Old Jul 13, 2011 | 05:16 PM
Jz6m's Avatar
hmmm it could be a blown head gasket let your car cool down and check your coolant to see if theres oil in it it would have that glazed look like if when theres oil in water or a brownish color
Old Jul 13, 2011 | 05:54 PM
Yup I Have Checked That To. No Smoke Or No Mixing Oil With Coolant Or Nothing.
Old Jul 13, 2011 | 05:59 PM
Jz6m's Avatar
damn last ting i can think of is to check the the front of the radiator for anything that could be blocking it
Old Jul 13, 2011 | 06:14 PM
Nothing There LMAO. It's Crazy Because If I'am Driving Normal On The HighWay It Starts Over Heating. But If I DownShift On The HighWay It Goes Back To Normal.
Old Jul 13, 2011 | 06:17 PM
grumblemarc's Avatar
The Grumpiest
Replace the radiator.
Old Jul 13, 2011 | 06:24 PM
WRD
Old Jul 13, 2011 | 06:49 PM
virgineg6's Avatar
i think your water pump is going bad!! if it was the radiator the engine rpms wouldnt matter
Old Jul 13, 2011 | 06:58 PM
You Have A Very Good Point!!!!
Old Jul 21, 2011 | 02:30 PM
Fixed The Promblem This Past Saturday Guys.
Old Jul 21, 2011 | 04:31 PM
motegicivic's Avatar
Ok what was it?????
There is no point to post a problem and not say what it is..........this forum is to help others with the same problem.
Old Jul 21, 2011 | 06:00 PM
Originally Posted by motegicivic
Ok what was it?????
I Did Write What Was The Promblem. But I Guess My Phone Did Not Post Everything I Guess By Looking At It.
Old Jul 21, 2011 | 06:03 PM
Well Here Is The Rest Of The Post That Did Not Show Up.
I Did The WaterPump. And It's Running MINT Now. But What I Don't Get Is That The Waterpump Did Not Leak. And The Metal Fins Were Fine.
Old Jul 21, 2011 | 06:23 PM
That is interesting, makes my worry about mine now since it is old.
When your car got hot did it do it running or at idle?
Old Jul 21, 2011 | 07:03 PM
REDEM1FTW's Avatar
In for the answer also! Im having overheating problems only after 10-15 minutes on highway. Im thinkin it might be waterpump also :O
Old Jul 21, 2011 | 07:25 PM
The Car Did It Both Ways. Idle And Running.
Old Jul 21, 2011 | 07:26 PM
Have You Checked All The Other Little Things??? Fan Switch Ect Ect????
Old Jul 21, 2011 | 07:29 PM
slowturbocx's Avatar
sounds like an air bubble.
Old Jul 21, 2011 | 07:50 PM
REDEM1FTW's Avatar
Icon3 Re: Over Heating EJ6 Hatchy AKA EK Hatchy
Yes fan switch, thermostat, radiator cap, bled coolant system... Basically everything I can think of except the waterpump :/ I made a thread yesterday but no one has really replied to it.
Sorry to threadjack, but here is the link to my thread incase anyone can help.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/93-civic-gsr-swap-car-overheating-only-highway-2960281/
pro306
18
Jul 4, 2013 05:35 AM
jmacc8
Honda Civic (2001 - 2005)
Aug 20, 2010 11:52 AM
nik1703
30
Aug 6, 2010 08:51 AM
kg4h2l0
Oct 23, 2004 12:30 PM
lostsol
Aug 19, 2002 08:38 PM
