How would you remove dried loctite from a threaded hole?
Old Jul 13, 2011 | 09:30 AM
Mikey3000's Avatar
Default How would you remove dried loctite from a threaded hole?
The 6 holes on my flywheel that are used for the pressure plate mounting screws have dried up loctite in them (after removing my clutch). How would you remove it? I was going to run a tap through there, but all I have is a "thread cutting" tap. I would think the better tap to use would be a "thread chasing" tap but I cannot find one from mcmaster-carr for M8-1.25mm thread.
Old Jul 13, 2011 | 09:59 AM
ToxicFabrication's Avatar
OG Fabricator
Default Re: How would you remove dried loctite from a threaded hole?
That tap size is very common. Just Google it and there are plenty of places selling them.
Old Jul 13, 2011 | 10:00 AM
that-guy's Avatar
thread chasing tap is exactly what you need. if you use a regular tap, the bolt will be out of tolerance and will never torque properly. in a bind, i have used a pick to get in there and run it around the threads. it won't get it all out like a thread chaser will, but it will get out majority of it
Old Jul 13, 2011 | 10:23 AM
Bakeoff's Avatar
Grab a spare bolt and use a cutting disc to run a notch up the length of the bolt. One is enough, but one on each side can be a real help if there's a ton of crap in there. It works just like a thread chaser and its free...
Old Jul 13, 2011 | 11:32 AM
Mikey3000's Avatar
Sweet, thanks for the advice guys!
Old Jul 13, 2011 | 01:13 PM
javierb14's Avatar
This method works really well
Old Jul 13, 2011 | 02:57 PM
xzodiackillerx's Avatar
Sears has the whole set of chasers
http://www.mysears.com/Craftsman-48-...ws?tab=details
Tyler Dirden
Apr 27, 2013 12:46 PM
Luckywhiteboi
Mar 6, 2009 03:58 AM
tree fingers
12
Sep 19, 2008 04:18 PM
legendboy
Jul 26, 2002 07:41 PM
ALF
Jul 7, 2001 10:31 AM
