How do you remove the timing belt from the cams?
Sorry im new at this, but im at the process of removing the cams, but cant remove them yet until i remove the belt. i know theres something im suppose to loosen first to remove the cams but not sure where its at. I got a b16 motor.
you dont have to take the engine mount off. but must take off some accesories if you have them. also its a 14mm socket you use.
only loosen it a little then the belt with have some stretch
Mad-Mike
Jun 2, 2011 07:35 PM
crxh22project
Feb 21, 2005 07:49 PM
