Drum brake thumping?
Old Jul 12, 2011 | 08:18 PM
deerman2701's Avatar
Default Drum brake thumping?
I just replaced the drums. Shoes. And all the springs and not when I brake I hear a slight thumping noise from the back end? I looked and everything is correct and the parts were brand new. The car stops excellent. Should I worry about it? Are the new parts just working in?
I noticed that if I'm going down the road and I use the e brake to slow down I hear the thumping noise as all speeds and the noise speeds up when I go faster and slows down when I am going slow.
I adjusted them accordingly and the e brake works very well aswell. Just that thumping noise is worrying me
It is a 99 civic lx sedan also
Old Jul 12, 2011 | 08:23 PM
EL Vap133's Avatar
Default Re: Drum brake thumping?
Did you buy the brakes from Autozone? I did once and had the exact problem, then I bought them from the dealer and problem solved.
Old Jul 12, 2011 | 08:49 PM
HNDA_4SHOOR's Avatar
^ +1 and kindly lubricate the metal to metal contact areas.
Old Jul 12, 2011 | 08:58 PM
I got them at advanced they are the wearevers
Is it safe to leave it alone with the noise there?
Old Jul 12, 2011 | 09:13 PM
Here is a video of whatthe noise sounds like...
it only happens when braking..
turn the video up to max
http://www.youtube.com/watch?v=ccL05l0EKrk
Old Jul 12, 2011 | 09:29 PM
EL Vap133's Avatar
I would replace them, it got on my nerves!
Linked's Avatar
when you changed the shoes, what were the condition of the previous ones? how was the drum surface?
do you only hear the thumping or does it also cause vibration in the car or the pedal?
Old Jul 12, 2011 | 09:38 PM
the previous shoes were smooth, just worn a lot..
the drum surface was smooth not egged or marked...
i spent 50 a peice for these drums.. cant return em now =[
no vibration just the noise..
i cant get it to recreate the sound when spinning by hand
Old Jul 12, 2011 | 10:12 PM
Linked's Avatar
nothing comes to mind
just make sure your wheels are properly torque,
like everyone said make sure all metal to metal points are lubed, including the spring points, the backing plate the drums contact,
and make sure the starwheel adjuster operates smoothly, i cant recall for civics but normal dual servo drum brakes self adjust by braking in reverse
Old Jul 12, 2011 | 10:14 PM
kk if yu guys come up with anythingelse lemme kno im gonna ride it out with my radio on =] and ac blasting...
<---pizza boy haha
Old Jul 12, 2011 | 10:18 PM
Linked's Avatar
<---pizza boy haha
if you do ever decide to try and fix it. experiment with it. you've pretty much hit a wall now until we can get some more info (AKA any awkward operation when you work with it
Old May 4, 2012 | 08:24 AM
SLATER97EX's Avatar
Just curious, did you ever figure this out? I'm having the same problem on my 02 Accord. Replaced my brakes with all new Wagner drums, shoes, and hardware kit. Had the thumping and thought maybe I got a bad set of shoes or drums so I exchanged everything and did it again. Same problem still! Just wondered if they maybe wore in or if you had to do something to fix it? Thanks!
Old May 4, 2012 | 09:22 AM
TheToaster's Avatar
Y'all check your hubs?
Old May 14, 2012 | 06:16 PM
Bad drums
Old May 14, 2012 | 06:24 PM
jbpnoman's Avatar
Thumping from drum brakes is usually caused by worn out brake hardware, or improperly adjusted shoes. When you replaced your shoes, did you replace the hardware? Did you properly adjust the shoes?
Shorthand
Jan 6, 2003 09:14 PM
99DXcoupe
Sep 24, 2002 09:28 PM
