2000 civic si **I NEED HELP***
Old Jul 12, 2011 | 03:58 PM
95inthe530's Avatar
Default 2000 civic si **I NEED HELP***
i recently replaced the head gasket on my 2000 honda civic si ( with the b16a) Its making a loud clicking noise its quiet at idle but as soon as the rpms go up it starts clicking
Old Jul 12, 2011 | 03:59 PM
rhymeshark916's Avatar
Default Re: 2000 civic si **I NEED HELP***
Valves? Put up a video and more information. Does it sound like a slapping noise?
Old Jul 12, 2011 | 04:32 PM
95inthe530's Avatar
http://www.youtube.com/watch?v=YJmSQ5vApYU here is the vid
Old Jul 12, 2011 | 04:40 PM
95inthe530's Avatar
I just posted a video of the noise its making? The head was taken to a shop resurfaced and all the valves were cleaned and adjusted
Old Jul 12, 2011 | 04:42 PM
Holy! That sounds pretty bad and sure sounds like it's slapping something. My guess is valves. Someone chime in.
Old Jul 12, 2011 | 04:52 PM
TypeRfit's Avatar
RESIDENT
Sounds like valves to me. My guess is that you have one if not both of your cams off timing. How did you secure them when you removed the head? How did you align timing when you put it back together? Did you rotate the assembly after everything was together to make sure "all" of the timing marks were in their proper place? i.e crank, both cam gear marks? Also did you torque the head properly?
Old Jul 12, 2011 | 04:54 PM
maxwellmercer's Avatar
Timing is OFF. No doubt.
Old Jul 12, 2011 | 05:12 PM
95inthe530's Avatar
I aligned the timing marks the crank to the mark on the timing cover ( the one alone not the three together) and the two cams i aligned the notch between the two
Old Jul 12, 2011 | 05:14 PM
95inthe530's Avatar
I rotated the crank by hand twice to see if i could hear any noise it rotated freely and everything seemed lined up after i got back to t.d.c.
Old Jul 12, 2011 | 05:34 PM
95inthe530's Avatar
any tricks to timing a b16
Old Jul 12, 2011 | 10:26 PM
95inthe530's Avatar
So is it the timing?????
Old Jul 12, 2011 | 10:41 PM
DO/\/\O's Avatar
timing is way off...valves are benting... take it apart again... ur gonna see ur valves messed up
hopefully not... but thats just what i think...
Old Jul 12, 2011 | 10:45 PM
95inthe530's Avatar
ok it was quiet the whole time it idled we only revved it three times :\
Old Jul 13, 2011 | 07:46 AM
hyperblu's Avatar
Definately valves slapping the piston... Triple check your marks, either you have one or both cam gears off...
Old Jul 13, 2011 | 08:46 AM
TypeRfit's Avatar
RESIDENT
Yes it is the timing. You could be off one tooth on one or both cam gears. The other thing I can think of is did you check where exactly the crank timing mark was when you disassembled everything? If you were off before you took it apart and put it back together where it should have been, well then your off.
dundfaukus
11
Jul 15, 2008 10:19 AM
N2OGSR
May 18, 2006 06:52 PM
eortizr
Aug 12, 2005 01:44 AM
d16y8turbo
May 8, 2004 02:46 PM
