91 Si wheel locked in place
Old Jul 12, 2011 | 01:58 PM
dmpd_ef's Avatar
Default 91 Si wheel locked in place
a friend has a 91 civic Si he just bought with a busted trans mount. the whole weight of the motor was resting on the rear and driver mounts, it made it most of the way home fine but right as he pulled up to his house the axle snapped because the motor was so slanted.(lucky he was in front of the driveway already)
today we installed a new mount and axle we purchased from a friend of mine. everything went smoothly until we noticed before lowering the car that the wheel was stuck completely in place. we lowered the car down and in neutral it does not roll in any direction and in gear it acts as if the e brake was on, what could be the problem?
notes
-axle snapped at the joints
-replaced tranny mount and pass axle
-wheel does not want to move anymore, in neutral or in gear
-car wants to stall when placed in gear and the clutch is released.
any help is appreciated, thanks
Old Jul 12, 2011 | 02:50 PM
KINGVEM^^ED6's Avatar
Default Re: 91 Si wheel locked in place
is the axles in right
maybe bad wheel bearing?
Old Jul 12, 2011 | 02:51 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
1.) What was the axle from?
2.) Back off the axle nut - if it frees it up then it is binding on the dust sheild. Did the replacement axle have an ABS ring on it or something?
3.) If 2 doesn't work then jack it up off the ground and see if it spins. If it does the axle is binding and it is too long.
Old Jul 12, 2011 | 07:34 PM
dmpd_ef's Avatar
I found out the axle came from an eg and I returned it. Called autoparts store and confirmed that hydro and cable axles have different part number
RDAYA0
Mar 22, 2013 02:22 PM
J_Dawg
Transmission & Drivetrain
May 27, 2009 11:23 AM
blazinrola80
Sep 12, 2007 08:03 PM
noleafclover
Jan 11, 2007 11:34 AM
NAEBP00Si
Sep 4, 2003 03:26 AM
