Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
What oil pan are you using?
Old Jul 11, 2011 | 09:30 PM
FlewByU352's Avatar
Default What oil pan are you using?
I would assume that most are running a baffled pan? Just curious as to what one you are using or your opinions on the different ones. I know there is Mugen, Moroso, Canton, PWJDM and Fastline Performance that are a self install into an OEM pan, Spoon, TODA... there's a lot lol.
Old Jul 11, 2011 | 10:03 PM
92integraVTECgsr's Avatar
Default Re: What oil pan are you using?
OEM. But I did just purchase a brand new Moroso baffled oil pan for $63, can't beat that steal of a deal. Gotta love craigslist. I've been running the OEM pan for 4 years on track and never had an issue.
Old Jul 12, 2011 | 03:45 AM
VTECIntegra9's Avatar
I had issues pre-baffles with my OEM pan... Added the baffles and now havn't had an issue since... however I am in need of an oil pressure gauge soo... I can't prove it's working yet.
-Teal... Who just realized he should get an Oil pressure gauge....
Mine:
Old Jul 12, 2011 | 04:30 AM
Lo-Buck EF's Avatar
Moroso 5.5 roadrace pan.
Old Jul 12, 2011 | 08:38 AM
jdmspoonitr's Avatar
I run the Mugen. Didn't want to fuss around with getting my OEM one welded and now I can sell the OEM pan, so it wasn't too bad really.
Old Jul 12, 2011 | 09:44 AM
sanimalp's Avatar
$cat /dev/urandom
same pan here. No complaints. Fits well with no leaks, as long as you wrap the turbo oil return and oil temp bung plugs with teflon tape before install.
At 5.5 quarts, the dipstick reads perfectly full as well.
Old Jul 12, 2011 | 10:20 AM
Pompiuses's Avatar
I'm running the oem pan in my b18c. Pressure has never dropped below 4 bars in any corner with 225 r compounds tires. Usually lies around 6 bars.
Old Jul 12, 2011 | 11:56 AM
bokals's Avatar
Z10 Engineering 5 QT pan with oil levels at 5.5 quarts i was still losing pressure.
Ditched the z10 pan and bought an OEM pan, Ed Sackly welded baffles and haven't had a issue since. Constant pressure in and out corners, thanks Ed! I've heard good things about the Mugen pan, however its costly. If you want to spend a little more look into the Canton Oil pans.
P30 Pan w/baffles
B16 999000 rev to the moon
Gauge indicated proof...
Old Jul 12, 2011 | 11:58 AM
Egezzy's Avatar
Spongebrad Squarepants
i myself am running an ed sackley oe p72 baffled pan. but still on the same boat..no gauge as of yet so no physical proof.
Old Jul 12, 2011 | 01:25 PM
GSRCRXsi's Avatar
Moroso 5qt road race pan.
Old Jul 12, 2011 | 01:45 PM
FlewByU352's Avatar
Do the Moroso pans hang lower or is the extra amount added to the back portion?
Old Jul 12, 2011 | 03:23 PM
GSRCRXsi's Avatar
The road race (steel) pan just has a kick out for the extra capacity and doesnt hang any lower than a stock pan. The aluminum one I think might hang lower. But the al one shouldn't be used for a RR car anyway IMO.
Old Jul 12, 2011 | 03:38 PM
get RIGHT's Avatar
<----- Mugen.
Old Jul 12, 2011 | 04:06 PM
Lo-Buck EF's Avatar
i should have my pan down in a couple weeks (silly blowed up motors). if you haven't decided yet, i'll take some pix of the baffles and trap doors.
Old Jul 12, 2011 | 04:33 PM
FlewByU352's Avatar
I am going on vacation for a month starting tomorrow so I'm in no rush lol. I like the idea of the Moroso having the oil drainback and temperature bung already welded in, seems like a great way to run a return off of a oil cooler and of course monitor temperature without having to tap into something. Only problem being they are $250 and that's not exactly what I would like to spend lol.
Old Jul 12, 2011 | 04:59 PM
Root of all Evil's Avatar
250 seems like a good deal to me. Just ordered my moroso.I'm interested in seeing how it seals because my oem one has always leaked a small amount even after many attempts and methods used to fix it.
Old Jul 12, 2011 | 05:48 PM
known's Avatar
oem pan with pwjdm weld in baffles
Old Jul 12, 2011 | 10:04 PM
Unknownek's Avatar
Old Jul 13, 2011 | 09:48 AM
Spitfire8o5's Avatar
old oil pan was smashed pretty bad, got the moroso baffled replacement.. love it! Oil I run the Castrol Edge and k&n filter.. puts up with track days and I drive there and back.. good stuff!
Old Jul 13, 2011 | 11:04 AM
Cynical 1's Avatar
moroso baffled road race pan.
no leaks or issues at all. does not hang any lower or fit any differently than stock (except for kick-out).
Old Jul 13, 2011 | 03:46 PM
Billy13's Avatar
i also run the moroso road race 5.5 quart pad. never any problem. for some reason takes almost 6 quarts to fill.
side not, i could not run the stock b18c pan, would not clear my z10 block girdle.
Old Jul 13, 2011 | 04:23 PM
Driven's Avatar
OEM with alloy craft baffle.
Old Jul 13, 2011 | 04:46 PM
jdmdohcek98's Avatar
moroso oem style baffled pan here.
Old Jul 13, 2011 | 05:04 PM
2fast4u831's Avatar
I'm really 2slow
kaizenspeed 7qt h2b pan with a baffle I put in.
Old Jul 13, 2011 | 07:08 PM
Lo-Buck EF's Avatar
the extra is to fill the filter
