interior lighting issue..
Old Jul 11, 2011 | 09:11 PM
theorigkav3's Avatar
Icon2 interior lighting issue..
Well, the problem i have is the light simply WILL NOT turn on when i open the door.. when i turn the switch on "on" it will turn on. but when i set the switch in the middle, and open the door, it will not turn on..
i looked at both door switches, and the connections, are fine.. what else could this be?
Old Jul 11, 2011 | 10:12 PM
Canadian_EF's Avatar
Default Re: interior lighting issue..
if you have the switch in the middle position and ground out the door switch wire, does the light turn on?
Old Jul 12, 2011 | 10:44 AM
nope.. only if i turn the switch to on. other then that, no.
Old Jul 12, 2011 | 11:54 AM
did you test the switch?
try a known good one, it's possible that the terminals on the dome light have corrosion or gunk on them. You could also just clean it.
Sometimes a blown fuse will cause weird interior lighting issues... Check fuse #12, it's a 15a.
Silly_banilly
Oct 29, 2016 01:48 PM
baozer
May 20, 2007 06:47 PM
kelliehager
Jan 14, 2006 07:23 PM
Built B16A
Aug 14, 2004 01:06 PM
