Help, exhuast heat shield?
Old Oct 2, 2002 | 05:20 AM
4drRacer's Avatar
Default Help, exhuast heat shield?
Im sometimes getting a ratling, grinding sound when the car is on neutral, but when I push it into gear the noise disapears, also happens when accelerating, between shifts(1st-2nd), and when moving slow. Could it be my heat shield? I heard somewhere that this could cause the ratling sound? Will there be a problem if I remove my exhuast heat shield? I hope this won't be a clutch problem.
Thanks for any advice
Old Oct 2, 2002 | 07:25 AM
deepnite's Avatar
Default Re: Help, exhuast heat shield? (4drRacer)
i replaced the stock exhaust piping from the cat back...there maybe slight rattle from the hangers...other noise problems could come from the cats. shield
Old Oct 2, 2002 | 08:52 AM
brcivic411's Avatar
Default Re: Help, exhuast heat shield? (deepnite)
there's an easy way to find out... just remove it and take it for a drive. if the sound is gone... you're done. if the sound is there, you know it's not your heat shields.
Old Oct 2, 2002 | 09:47 AM
mist sITR's Avatar
ya i had the same prob. all i did was unbolt the heatshield from my exhaust and cat and it went away takeing it off wont hurt anything un'ess u plan on driving through tall grass
ih8speedbumps
Jan 4, 2014 03:17 AM
patrEK9
18
Mar 30, 2010 09:15 AM
optikal_blitz
May 15, 2003 05:16 PM
oryanh
Aug 12, 2002 08:57 AM
E Swift
Sep 10, 2001 11:05 AM
