how to make 200hp from a f22b1
I am trying to build up my 94 accord ex sedan 5spd on a budget. I have just about completed my susension and I/H/E but where do I go from here?
I am wanting to build the f22b1 all motor and keep my stock tranny, clutch, axles etc. I know I won't be able to drop the clutch from 5k rpm on a regular basis but otherwise, will these stock components handle 200hp?
Also, what is the cheapest and best way to get 200hp out of the f22b1. How would you approach this project?
The abosolute cheapest way to do it is a 50 shot of NOS. But I consider that cheating
My F22b1 puts out 160-170hp to the wheels with a balanced and blueprinted motor, exhaust, and a very very well tuned engine management system.
Despite what some people say, it is a potent motor. It is also one of the most durable 4 cylinder motors honda makes.
easy, yuo just need to make a broad flat 155+ wtq and have a rev range up to 7200, so give me a few months and ill tell you the complete list
[Modified by SOHCArchangel, 10:28 AM 10/2/2002]
Yeah, I considered getting N2O but now I am thinking all motor f22 would be unique and would teach me a lot about the internal workings of an engine. I am pretty competent with suspension and I understand the basics of how an engine works but a lot of the internal mod stuff is completely new to me.
What exactly is balanced and blue printed??
What are you running for engine management? modified ECU? VAFC?
balanced and blue printed means that the engine was rebuilt to very exact specifications so it can run exactly how it was designed.
I'm using the EFI PMS http://www.efisystems.com/
the VAFC look is a fisher price toy compared to the EFI PMS.
AEM makes one but the EFI is better from what I hear.
200whp or 200hp? Thats a pretty pretty noticeable difference. We need to establish that first before we can help you.
A stock clutch is going to slip like crazy with either of those numbers. An aftermarket clutch is a necessity. Axles would be fine, the tranny would be fine.
Yep, (155x7200)/5250=212The math is the easy part. Getting there is where you come in!
The Accord/Prelude drivetrain is stronger than the Civic/Integra's. It will handle more torque. the only thing you really have to worry about is CV boots. I've had to replace axles twice because of worn boots.
as for the blueprinting goes, i don't have much knowledge about it, but i can tell you one or two things about it.
When they build your engine blueprinting it, it means that they measure everything and make it all the same clearences between rods and bearings, the crankshaft and bearings, etc...
they also make sure that the clearences are correct for the oil film, i've heard that blueprinting is getting the engine build just as stock specs, but i don't think is true cuz the engine wasn't build for racing. you would need to search more about blueprinting.
And if i wrote something that's not correct, please correct me, my main lenguage is spanish.
Hope it helps and good luck, keep me posted on you progress
For the money, I would turbo the F22b1. I've seen the motor take 8-10psi stock without problems.
Low compression + strong internals + long geared tranny = Excellent turbo application
my stock tranny, clutch, axles etc....will these stock components handle 200hp?
[Modified by niedejb, 4:10 PM 10/2/2002]
Since most F22b1s probably have around 100K it just doesn't seem like a great idea to go turbo if you need to daily drive the car and run on stock internals.
I'm not going to argue power since that was beaten to death a few months ago.
H22 has less miles and reliabilty!
Both engines are just as reliable. But I've seen the F22b1 take more of a beating.
On a daily driver turbo, I wouldn't go more than 8psi but some people do with F22b's.
yea, we don't need to talk about power. we all know the H22 is more powerful.
IMHO, the F22b1 is the best bang for the buck. prices for H22's are skyrocketing because it is easier than ever to swap them into a Civic/Integra. Plus it is comparable in price to a high-end B series motor but has more HP and waaaay more torque.
OK - but lets get back to the question...
What would need to be done to get an f22b1 pulling 200hp at the crank?
What kind of internal mods are we talking about beyond the I/H/E? I am going to need to rebuild my engine anyway at some point. What would I need to do for a performance rebuild and would it cost much more than a regular rebuild?
Youll have to go with higher compression pistons. http://www.raceeng.com has 11:1 F22b1 application.
Doing that and a reground cam is the only way to get you there.
Unfortunately youre going to need some sort of standalone engine management too. That compression and a different cam will make your stock fuel/timing maps worthless.
My $.02
My $.02
