Can't get speedometer to work!
Old Jul 11, 2011 | 03:23 AM
Cauthan's Avatar
Default Can't get speedometer to work!
Hello. I am new to the site. I have browsed the forums in the past, but first time signing up and posting. I imagine I will be posting a lot in the future.
A little over a month ago I purchased a 94 Honda Civic DX hatchback. It had some modifications done to it before I purchased it that I may share later, but those relavent to this post are as follows:
- D16Z6 VTEC and EX manual 5sp trans out of 90,000 mile EX coupe.
Now, since I got this car, it has had an issue with the speedometer/odometer/trip. It will work, but only VERY rarely. I have removed the guage cluster. I took some fine grit sandpaper to the traces, and got them nice and polished down to nice clean copper on the contacts behind the speedometer, as well as the 4 tabs along the sides where the socket plugs in. I still cannot get the speedometer to work. Any suggestions?
Old Jul 11, 2011 | 03:26 AM
hondatuner34602's Avatar
Default Re: Can't get speedometer to work!
did u check the vechicle speed sensor connector it maybe unplugged? its located right on top tranny near by the rear engine mount area
Old Jul 11, 2011 | 03:27 AM
Cauthan's Avatar
When I looked at it, it seemed to be plugged in.
Edit: Just went out, and made sure. It was plugged in securely. I unplugged it, and plugged it back in to be 100% certain
Edit 2: Just drove it down the street to see if that might have worked. Still not working.
Old Jul 11, 2011 | 04:28 AM
EsotericImage's Avatar
Retired Moderator
Sometimes the VSS takes a **** or more often its the plug that inserts into the sensor that corrodes and doesnt make contact anymore. remember, the car is close to 18 years old.
You cant buy just the plug, but you can try and cut off the plug, try and take it apart and clean it then solder it back together.
Old Jul 11, 2011 | 05:37 AM
Former User's Avatar
Is CEL code 17 thrown?
Old Jul 11, 2011 | 05:54 AM
Cauthan's Avatar
Nope. Just went and tested. Only thing it gave was 11 (1 long, 1 short)
Old Jul 11, 2011 | 06:51 AM
That's probably code 10 and code 1.
Old Jul 11, 2011 | 10:16 AM
frankenghia's Avatar
Pull the vss plug off and look inside. Its probably corroded. Its common on these years. I just went through the same thing on my 94 coupe. I ended up having to replace the pigtail at the vss and also I went through two speedos to find a good working one. Its worked perfectly ever since.
Old Jul 12, 2011 | 06:09 AM
Cauthan's Avatar
I went out, and pulled the plug from the socket, and saw no corrosion.
Old Jul 12, 2011 | 07:34 AM
If code 17 is not thrown, then the cluster/speedo is probably the problem.
send2artem
20
Mar 28, 2012 04:14 AM
watacanga
Nov 29, 2007 08:47 AM
hungdat89
Apr 19, 2007 02:49 PM
NA95d16z6
Feb 25, 2005 01:55 PM
redex94
Feb 12, 2003 06:41 PM
