How change transmission fluid?
theres a drain plug on the transmission just drain the oil like u would normal oil and than fil it up with Honda ATF or MTF depending on what tranny you have it is so much better on the tranny than crap from parts stores
i would also recommend chaning plugs (NGK), Wires (Desno/NGK), Cap & Rotor, PCV Valve(OEM HONDA), Fuel Filter and getting some seafoam trough the engine or u can do BG44K which i use an dit works great this will give ur y8 a refreshment and great MPG try to stay oem and take care of the engine dont buy autozone crap
BikeSpike
Aug 26, 2003 08:21 PM
