99 civic motor mount nut unwelded from inside frame :((((
Old Jul 10, 2011 | 12:28 PM
dpkelly's Avatar
Icon2 99 civic motor mount nut unwelded from inside frame :((((
Really need some help here folks. I changed my own timing belt and water pump and I wanted to remove the drive side upper engine mount to reach things.
When loosening one of the 3 bolts, the nut became unwelded from inside the frame, argh! Now I can't tighten the bolt and I hear clunking sounds when engaging into 1st gear or going over bumps :-(.
Is the only solution to cut into the frame from the other side inside the wheel well? It seems Honda didn't put that bolt on correctly last time.
If you look into the picture, you'll see it's between the engine mount and the power steering resevoir.
Old Jul 10, 2011 | 12:51 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 99 civic motor mount nut unwelded from inside frame :((((
Start cutting. You're talking about a 12 year old car. These things start happening. Especially in climates that are prone to rust.
scubacamper
Jul 4, 2015 10:29 PM
B_Swapped93
May 30, 2013 08:34 PM
TEGRA98GSR
Apr 21, 2010 09:47 PM
d-man88
Jul 18, 2005 04:29 PM
