Suspension & Brakes Theory, alignment, spring rates....
KONI STRUTS OR TOKICO STRUTS ARE BETTER FOR ENTRY LEVEL STREET USE
Old Jul 10, 2011 | 10:21 AM
lowedageneral's Avatar
Default KONI STRUTS OR TOKICO STRUTS ARE BETTER FOR ENTRY LEVEL STREET USE
WHICH ONE IS BETTER FOR A COMFORT ENTRY LEVEL STREET USE ON A 95 HONDA ACCORD
KONI (ORANGE) OR THE TOKICO (BLUES)
NOTE I KNOW THESE AREN'T THE BEST STRUTS SO PLZ ADVISE ME ON THE SELECTED ONES
Old Jul 10, 2011 | 03:16 PM
PreyStayShun's Avatar
Default Re: KONI STRUTS OR TOKICO STRUTS ARE BETTER FOR ENTRY LEVEL STREET USE
What is entry level street use? Are you lowering the car?
If you just need an OEM replacement go w/Monroe.
Old Jul 11, 2011 | 06:20 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
i would only use those shocks if you were using a stock honda/acura spring.
if you're trying to use some different springs, lower ones, i would save up some more dough for koni yellows. they are the only ones that will hold up. seriously. they're worth the money.
if you don't wanna spend that much for the yellows, run a stock spring if you dont want those koni oranges or tokicos to blow up. otherwise they wont last very long and your car will seriously ride like ****.
Old Jul 11, 2011 | 06:30 PM
Libertariat's Avatar
Ek Forever y0!
Isn't it bad when you wouldn't recommend either? I feel obligated to convince you to not waste your money and be a bit more patient when buying parts.
If you just need replacements buy Monroe like the above poster said. Otherwise be patient and wait until you can afford something quality. Trust me, I've learned the hard way and you'll be a lot happier in the end.
jdm_94
Jul 13, 2009 12:43 PM
jakeiscool
Suspension & Brakes
12
Mar 23, 2005 02:16 PM
cstoltie
Sep 16, 2002 10:41 PM
B18Redline
May 11, 2002 10:38 AM
