alternator help! battery light
Old Jul 10, 2011 | 04:22 AM
nikez4me's Avatar
Default alternator help! battery light
okay so my alternator went outt butt it wasnt that bad the battery light hadnt came up yet. so i go buy a new alternator along with a belt also go recharge my new battery install everything the right way ive done this before butt then i turn the car on and the battery light stays on i checked all the fuses everything good any suggestions?
PLEASE HELP!
IM THINKING THE ALTERNATOR CAME DEFECTIVE
Old Jul 10, 2011 | 04:39 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: alternator help! battery light
The "battery light" is ONLY for the alternator. If the light is on then most likely it is a defective alternator. Other potential problems: wiring could be messed up, ELD may have problems (doubt it), fusible link may have blown... Check to be sure you battery registers ~12.5 volts with the cables off of it, just to be sure you cover your bases.
Old Jul 10, 2011 | 08:27 AM
nikez4me's Avatar
ok whats the ELD and the fusible link?
the car is at the shop so tommorow im going to tackle that problem i think first im going to take the alternator off and go bench test then ill go from there
Old Jul 10, 2011 | 08:49 AM
DO IT ON ALL FOURS
A fusible link is just an inline fuse that they use from the factory. Prevents you from ruining your fuse box in a short/overload condition.
Old Jul 10, 2011 | 09:25 AM
nikez4me's Avatar
thanks bro ill check it out
Slacker87
17
May 10, 2017 07:30 AM
haywyre
Oct 9, 2008 12:27 PM
fe519
Sep 23, 2003 03:25 AM
Alexnaderkeith
Sep 10, 2003 08:32 AM
BoostingLS
Oct 7, 2002 07:24 AM
