ecu zc engines questions
Old Jul 9, 2011 | 07:53 PM
tevezjdm3012's Avatar
10 Year Member
Default ecu zc engines questions
i have a 91 civic sedan ex i blew my motor so i put a sohc jdm zc in non-vtec, im obd0 im multi-point stock ecu, i bought a p28 ecu and a jumper harness but havent put it in......now if i want to put it in what do i need???? do i need a obd1 zc distributor? or will the stock distributor work? and do i need to make any changes to my manifold?
Old Jul 10, 2011 | 04:59 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: ecu zc engines questions
You have a lot to read... It also helps to use the SEARCH function.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-91-crx-ef-civic-frequently-asked-questions-faqs-1508680/
If you are going OBD-1 then NO - your OBD-0 distributor will not work as they have different reluctor rings. Read a lot before you do this conversion. It is very simple, but knowledge is POWER!!!
edm_ef8
Oct 13, 2009 03:47 PM
Canadian_EF
10
Aug 26, 2009 06:52 AM
BoostdRex
16
Nov 26, 2005 11:39 AM
RotiEatter
May 7, 2004 07:11 PM
hondahybrids
Oct 13, 2003 10:06 AM
