EF motor
Old Jul 9, 2011 | 06:45 PM
SIty808's Avatar
Default EF motor
Blown head gasket on a 16 valve what motor is that a D15B1 OR B2 SOHC?
Old Jul 9, 2011 | 06:50 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: EF motor
You didn't say what car you have... There is more than just one "EF" motor anyways. Also you could just look at the block ID about half-way down - transmission side - and figure it out yourself.
Old Jul 9, 2011 | 07:18 PM
SIty808's Avatar
its a 1991 honda civic ef si hatch
Old Jul 9, 2011 | 07:21 PM
gnxpro24's Avatar
should be a D16A6 unless the engine was ever swapped
Old Jul 9, 2011 | 07:23 PM
SIty808's Avatar
nope stock motor
Old Jul 9, 2011 | 08:54 PM
SIty808's Avatar
i think its a d16a6 16 valve non vtech
Old Jul 9, 2011 | 09:02 PM
gnxpro24's Avatar
if its stock engine just look on the engine block it will say
Old Jul 9, 2011 | 09:13 PM
SIty808's Avatar
thanks its a d16a6 now i gotta get parts for the head
Old Jul 9, 2011 | 09:16 PM
gnxpro24's Avatar
make sure to get oem honda stuff or youll have problems.
Old Jul 9, 2011 | 09:23 PM
SIty808's Avatar
so get the parts from honda is what your saying
Old Jul 9, 2011 | 09:28 PM
gnxpro24's Avatar
you can find oem stuff online or dealership. using anything cheap is a mistake. if youre not upgrading the motor for more power use an oem headgasket oil seals and stuff and youll be good
Old Jul 9, 2011 | 09:35 PM
SIty808's Avatar
checking for oem parts but it keeps showing forums
Old Jul 9, 2011 | 09:45 PM
KINGVEM^^ED6's Avatar
just call honda dont buy the bull **** autozone sells
make sure you get a water pump and timing belt and tensior while your at it
Old Jul 9, 2011 | 09:46 PM
gnxpro24's Avatar
not too cheap http://www.hondaautomotiveparts.com/ maybe someone else will chime in with a cheaper site
Old Jul 9, 2011 | 09:48 PM
SIty808's Avatar
i gotta buy new water pump anyway mine broke i just replaced timing belt jus gotta fix the head
Old Jul 9, 2011 | 09:52 PM
seems to me you do **** *** back words
why would you replace your timing belt and not the water pump to?
just replace everything or your just going to keep having problems bruh
Old Jul 9, 2011 | 09:54 PM
SIty808's Avatar
replaced timing belt then the water pump broke n blew the head gasket. water pump n head gasket jus gotta be changed
Old Jul 10, 2011 | 04:52 AM
DO IT ON ALL FOURS
It's good you figured out your engine didn't come with a phone on it. WHY did you not just look for yourself to figure it out? If you are capable of changing the headgasket then... I am just going to sit back and watch for his "My car won't start/ I bL0 mAh cAhRz ooP y0" thread... Have fun!
Old Jul 10, 2011 | 05:03 AM
1990edsedan's Avatar
1) take the head to a rebuilder. Have them check the head and replace any bent valves(which I bet money on). They will refurb it and resurface the head.
2) buy a new waterpump and tensioner - christ go ebay if you're lazy.
3) buy an adjustable cam gear - since the rebuilder will probably shave your head a bit, this will allow you to adjust your cam timing to compensate.
4) if you can't handle the preceding 3 points, then bring the car to a decent mechanic.
Old Jul 10, 2011 | 04:43 PM
BiG ChOr!Zo's Avatar
didn't go oem and still haven't had no problems here...!!!
jdblock
May 1, 2016 12:48 PM
bgtviper
14
Jan 30, 2007 06:30 PM
Crimson_Tide
Aug 24, 2005 08:10 AM
vulcandan
Oct 30, 2002 07:14 AM
