No clutch adjustment left
About a month ago I was driving my civic when it started being very difficult to change gears. Then shortly after I had no clutch at all. I popped my hood and had about 2-3 inches of play on the release bearing lever which left me with no more threads to adjust the clutch cable. I pulled everything apart and found this..............
So considering I didn't know how long everything else would last, I bought a new clutch kit that replaced the pressure plate, clutch disc, release bearing, pilot bearing and also replaced the rear main as well just because I was already in there. I put everything in and I am still having the same problem with the 2-3 inches of play and no more threads to adjust my clutch cable. I even went so far as to replace the clutch cable and I still have the same problem.
Any ideas???
Any ideas???
miguey310
Sep 2, 2009 04:20 PM
Yaa
Nov 12, 2006 05:45 PM
