teggy clutch issues
Okay so the other day i was driven ripped first went to shift into second an the clutch pedal like stuck down an would'nt let me shift into second. odd so i pulled the pedal back up and it went into gear. now normal driving pedal seems fine only wen i rev it out an try to shift it wont let me an the pedal gets stuck. so i bleed it a few times that didnt work, then just replace the CMC and the slave cylinder bleed it still have the same problem .........gah!
Does anyone have any ideas of what might be goin on .thanks
If you can not shift gears when clutch is in, [stuck or not] it is a clutch problem.
Is the "Clutch Release Fork" moved all the way in when clutch peddle is stuck to the floor? 94
yea i was worried about that but its weird if i dont like rev gears out it shifts fine but as soon as i got to rip a gear i go to shift an the pedal like gets stuck an i have to pull it bak to shift it wierd guess i gotta pull the trans off an put a new clutch in
guess i spoke to soon it was good for like a day this morning there was a vette next to me went to get on it same thing happen clutch got like stuck an wouldnt go into gear pulled pedal up pushed it bak in shifted fine so annoying
fred92htch
Aug 23, 2004 01:54 PM
