Power Window Problems 96 Civic LX
The other day, my rear drivers side power window decided it would not roll back up. It rolls down just fine, and I can hear the motor working, but it won't roll back up. So, I replaced the motor/actuator and switch, and I still have the same problem! I figure it is the wiring harness now, but I don't know where to go from here. On a related note, the master power window controls only work the drivers window and rear passenger window. All the windows work from their own switches (except the drivers rear, described above) just not from the master. I tried replacing the switch there too, but the problem has persisted. Any help would be greatly appreciated.
there is probably a short in the wire after the master switch where it goes under the dash. im having the same problem. my RR window only works when the driver side door is open all the way, but once its closed it wont work from the master.
dantimo
20
Mar 10, 2014 09:24 AM
92-CivicLX
Sep 23, 2013 07:46 AM
bighoss77
Aug 16, 2012 08:44 PM
