Longer Starter Bolt broken, 1997 Sol B16A2
Old Jul 8, 2011 | 04:26 PM
mazaa's Avatar
Default Longer Starter Bolt broken, 1997 Sol B16A2
Hi,
I was changing out the plunger n contact on my starter and in the process the bottom starter bolt has broken deep inside the hole, I first tried to slowly drill it out, but its not really working and the last thing I want to do is break a hardened BIT/extractor in there, or better yet drill into the engine....
Since the top bolt is ok, I want to thread the bottom hole with a 12mm x 1.25 tap, approximately an inch long, then use a > grade 10 bolt, that should be ok right?
Many thanks, btw I have been lurking around since I acquired my 1997 1 owner blk VTEC del sol last Nov, I really like the mpg, and the fun combo factor
http://www.flickr.com/photos/50011705@N07/5482553714/
http://www.flickr.com/photos/50011705@N07/5482553706/
Old Jul 22, 2012 | 06:16 AM
sloshred's Avatar
Default Re: Longer Starter Bolt broken, 1997 Sol B16A2
The same thing just happened to me on my 1999 civic and I was thinking of tapping the bottom hole as you suggested. I didn't see any replies to your post. Did you end up doing this and did it work? thanks, Ed
ChrisFred96
Transmission & Drivetrain
Aug 1, 2016 03:36 PM
Wrona
10
Dec 15, 2011 04:23 PM
Scud
Nov 2, 2007 10:32 AM
90Integra
May 31, 2006 07:04 PM
hoehouseworker
May 15, 2005 06:57 PM
