Clunking noise while driving very slow?
Old Jul 8, 2011 | 02:30 PM
Shpongled's Avatar
Icon2 Clunking noise while driving very slow?
I have a 92 hatch with an f20b. I just replaced the passenger side axle and ball joint.
I Started driving down my driveway and it's making a clunking noise? I didn't drive it any further then half way down the driveway. I'm pretty sure it's not the axle.
I am at a loss. Any help would be appreciated!
Old Jul 8, 2011 | 03:19 PM
motegicivic's Avatar
Default Re: Clunking noise while driving very slow?
Are you turning? Typically it is the CV joints.
Old Jul 8, 2011 | 03:25 PM
Shpongled's Avatar
Not turning. Just going straight about 5 mph. To scared to go any faster.
Old Jul 8, 2011 | 03:54 PM
Gustav129's Avatar
What did you torque the wheels to?
Old Jul 8, 2011 | 09:10 PM
Shpongled's Avatar
The lugs? 80
Old Jul 8, 2011 | 09:31 PM
CivicBlacksheep's Avatar
10 Year Member
Does it speed up as you go faster?
Old Jul 8, 2011 | 09:56 PM
Gustav129's Avatar
Ok, just making sure. It happens to forget torquing one wheel, and you pull out, cluck clunk clunk..... No harm in double checking.
Another thing to check, is the caliper all the wat tight on the bracket.
Those are probably the two easiest things to check first.
Old Jul 8, 2011 | 11:40 PM
Dee_333's Avatar
Look at all the suspension from under the car and see if there is anything rubbing on the wheels/tires or anything of that nature.
Old Jul 9, 2011 | 03:31 AM
BryanM.'s Avatar
Resident Gearhead
Upper ball joint(s)?
Grasp the upper part of the knuckle where it meets the upper control arm ball joint and yank on it. Check for play with the suspension loaded.
Make sure all fasteners are tight.
Old Jul 9, 2011 | 07:13 AM
JDM-sol 89's Avatar
Also, check your tie rods; I've heard those make some clunking noises while driving.
Old Jul 9, 2011 | 08:20 AM
Gustav129's Avatar
Just posted this in another thread with a broken tie rod end:
To inspect them in the future, when you lift the front end and put jack stands (or jack if you are doing one side at a time) under the control arm, put your hands at 12 and 6 oclock, and push on the top and pull on the bottom a couple times, take noice of any clunks or looseness.
Then put your hands at 6 and 3 oclock, shake tire back and forth, take note of any looseness.
-If there's the same amount of movement in both top to bottom and side to side, you have a bad wheel bearing
-If you only have movement top to bottom, then suspect a ball joint
-If you only have movement side to side, then start looking at inner and outter tie rod ends.
Old Jul 11, 2011 | 03:46 AM
Shpongled's Avatar
Nothing was rubbing anywhere. Wasn't the ball joints or the tie rod. I jacked it up and started spinning the wheel. This is what happened. Thanks everyone for your help.
http://www.youtube.com/watch?v=HyyXV9LlLzU
Old Jul 11, 2011 | 12:24 PM
hafast's Avatar
cv joint fully seated in the trans?
It almost looks like the shaft of the cv joint is hitting the suspension fork of the strut.
I tell ya I watched that video 3 times and every time is said WTF.
Old Jul 12, 2011 | 05:29 PM
Shpongled's Avatar
It's all the way in there and it's not hitting anything.
Old Jul 12, 2011 | 06:30 PM
redm3turbo's Avatar
got some zip ties...?
:D
Old Jul 12, 2011 | 08:29 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Broken axle? Just a guess. I'm curious too. This kind of work is not really my forte.
Old Jul 12, 2011 | 09:08 PM
Dontoh's Avatar
i've diagnosed so many "weird noise from front end" jobs, never seen anything like this.. you have me curious lol.. watched that vid a couple of times, no clue
Old Jul 29, 2011 | 12:35 PM
Shpongled's Avatar
Anyone else? I really don't want to have to take it in.
Old Jul 29, 2011 | 12:54 PM
94EG8's Avatar
Seagull Management
It looks like the axle angle is too steep in the video and causing it to bind and clunk at the inner joint.
Old Jul 29, 2011 | 12:59 PM
b20acura's Avatar
Is it me or your axle shaft looks a bit too long that it's bending the cv boot all weird?
Old Jul 29, 2011 | 01:04 PM
Shpongled's Avatar
The car was jacked up. It's not steep when its sitting on the ground.
Old Jul 29, 2011 | 01:38 PM
b20acura's Avatar
Ah, got it. I have a clunking problem too. But it's only when I'm driving and hit a bump. Cannot figure it out because I cannot drive and hit a bump and look at the car at the same time, lol. Well, good luck fixing your problem.
Old Jul 31, 2011 | 01:00 PM
Shpongled's Avatar
Old Jul 31, 2011 | 01:04 PM
Dontoh's Avatar
still nothin, my man?
try taking everything apart, suspension, cv shafts etc.. and just put em back together.. when you put your cv shaft back in it'll click when its fully seated, its important- make sure it clicks
Old Jul 31, 2011 | 01:41 PM
Shpongled's Avatar
Went outside and jacked it up, took the tire off, put a block on the brakes to take the axle nut off. As I twisted it, it didn't break loose. It just made this clicking sound UGH!
