which distributor to use obd0 to obd1 b16a
Old Jul 8, 2011 | 01:29 PM
jrmacho22's Avatar
Icon2 which distributor to use obd0 to obd1 b16a
I've been searching all over google and have found very little and fuzy information on which distributor to use when converting over from obd0 to obd1 B16A. I recently purchased a B16A which has been converted to obd1. it didnt come with a distributor. I've seen a few forums which talk about just putting in any obd1 vtec dizzys. which clearly isnt right.
i searched a few auto parts stores for obd1 b16 distributors and a few come up as compatable TD-42u, td-44, and td-68
. i have a td-42u, tried it and only 1 bolt will be able to be used. i can probably modify it to fit the other 2 bolts but i would not be able to adjust the timing.
What options do i have? and what dizzy number should i actually use?
Thanks
Old Jul 8, 2011 | 01:36 PM
ricky00's Avatar
Default Re: which distributor to use obd0 to obd1 b16a
what year is the motor
Old Jul 8, 2011 | 02:01 PM
jrmacho22's Avatar
if the block is with the original cylinder head then i would say its a 89/ 90. (pr3-1 if that means anything) The serial number on the block starts with 1008 (88-91)
Old Jul 8, 2011 | 02:05 PM
ricky00's Avatar
run an obd0 distributor and repin the wires to obd1 and if u can find obd0 dizzy... or custom a obd1 dizzy to fit..
Old Jul 8, 2011 | 02:49 PM
jrmacho22's Avatar
thanks for that info. so i guess a td22 will work just as fine as a td42u (which is a sohc obd1 distributor)?
efjones9
Apr 16, 2010 11:35 PM
carlthecrx
May 13, 2008 02:08 PM
salman
28
Jun 5, 2006 11:58 AM
Turbo_Mike
Sep 17, 2005 02:25 PM
highvelocitynyc
Aug 17, 2003 10:17 PM
