which intake will fit?
I would go by chassis. Chances are the throttle body will be close to the same position between engines, but the shock tower, battery, headlights, etc will be significantly different between chassis.
x3 on the chassis - you can always cut or add piping as well.
You could just get an Ebay pipe and a Dryflow or K&N filter on it. Unless you're in cali and need that carb exempt sticker
