Messed up ECT (temp sending unit) wire
Old Jul 8, 2011 | 08:04 AM
popppinvtec's Avatar
Default Messed up ECT (temp sending unit) wire
Anyone know how to fix is
Everytime i turn my key on the needle goes up. I know what it is i juss dont know how to fix it. Also if i mess with the wire it will either stay down or go right back up either one . Any help or suggestions would and would be appreciated.
Thanks in advance
Old Jul 8, 2011 | 08:26 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Messed up ETC wire
fix the wire. Yes, it's just one wire.
Old Jul 8, 2011 | 08:29 AM
How do i fix the wire though ?
Old Jul 8, 2011 | 08:32 AM
NVturbo's Avatar
O.G. triple O.G.
Cut the wire at the end of the OEM plug (at the sensor on the block) and use one of those bullet female connectors. Crimp, heat shrink, and you're good to go. Less than 2 minutes of work.
Old Jul 8, 2011 | 08:35 AM
Thanks
Old Jul 8, 2011 | 08:36 AM
Your talking about the one thats on the head right ?
Under the dis.
Old Jul 8, 2011 | 08:37 AM
NVturbo's Avatar
O.G. triple O.G.
Yes.....that one.
grumblemarc's Avatar
The Grumpiest
He's talking about the wire that you're talking about in your very first post.
Old Jul 8, 2011 | 08:40 AM
Ill try it and see how that goes
Thanks man
Old Jul 8, 2011 | 08:43 AM
Former User's Avatar
Default Re: Messed up ECT (temp sending unit) wire
Also measure the resistance of the temp sending unit itself. It or the connector/plug may be bad or contaminated with oil.
Old Jul 8, 2011 | 09:25 AM
Alright thanks
williamcollins
Jul 8, 2017 01:24 PM
San-Wan
Sep 30, 2008 07:28 AM
14bcoupe
Welding / Fabrication
12
Apr 19, 2005 11:20 AM
Slvr_CRX
Feb 23, 2005 07:27 AM
5STAR3
Jan 22, 2004 03:47 PM
