98 civic d16y8 - can someone help? - injectors wont spray
Old Jul 7, 2011 | 08:01 PM
joshs98civic's Avatar
Default 98 civic d16y8 - can someone help? - injectors wont spray
i have a 98 civic d16y8, i have fuel going to the rail but injectors wont spray, i check the ground on the injector it is grounded until i turn the key over then its gone, if i manually ground the injector it will spray and will start to run but real rough. i already checked all fuses and replaced main relay and ecm any advice?
Old Jul 7, 2011 | 08:08 PM
Former User's Avatar
Default Re: can someone help - injectors wont spray
Is there continuity to body ground at ECU connector terminals A10, A23, A9, and A22?
Old Jul 7, 2011 | 08:10 PM
yes the car was running good then just shut off,
Old Jul 7, 2011 | 08:11 PM
could it possibly be an ignition switch?
Old Jul 7, 2011 | 08:12 PM
Did you use a multimeter to do the tests I mentioned? If so, what resistance did you measure at each terminal?
Is there spark at the plugs?
Old Jul 7, 2011 | 08:15 PM
i didnt write it down car is in garage can post tommorow, yes there is spark
Old Jul 7, 2011 | 08:17 PM
if theres spark wouldnt that eliminate a bad ignition switch
Focus on retesting those terminals of ECU connector A. That's where the problem likely lies.
http://www.phearable.net/tech/wiring...schematics.gif
Old Jul 7, 2011 | 08:18 PM
A bad ignition switch would NOT cause the problem you are having.
Old Jul 7, 2011 | 08:21 PM
also when i turn the car over there is a interment clicking noise from the ecm could that be anything
Old Jul 7, 2011 | 08:22 PM
Old Jul 7, 2011 | 08:29 PM
what resistance should i be looking for
Old Jul 7, 2011 | 08:31 PM
Less than 100 Ohms. Do you know how to do a continuity to body ground test?
Old Jul 7, 2011 | 08:35 PM
no my neighbor did it but cant trust him, can you explain please
Old Jul 7, 2011 | 08:58 PM
Disconnect the battery. Unplug ECU connector A. Set the multimeter to measure resistance (20 or 200 Ohm scale) or continuity. Touch one meter probe to the metal frame under the dash and the other meter probe to one of the four indicated ECU terminals.
Old Jul 13, 2011 | 04:40 PM
I. Have no geound in any of the terminas. You said I get ground from 2 4 6 13 14
Old Jul 16, 2011 | 05:39 AM
I'm not sure how your answer relates to my question.
eliseosworeze
Feb 16, 2014 09:07 PM
Johannes civic
18
Feb 22, 2013 09:45 AM
shaylude01
Aug 14, 2010 08:47 PM
JATz28
Oct 26, 2008 10:52 AM
SSBGSR88
14
Apr 2, 2004 09:57 AM
