Axle Binding
Old Jul 7, 2011 | 06:39 PM
f20cmx5's Avatar
Default Axle Binding
Whenever I make a left turn in my k20a2 crx with drive shaft stage 0 axles I get a terrible vibration from the right front. The lower the front gets the worse it gets. Could this be axle binding? A bad bearing? When I jack the car up and check for looseness in the suspension I can't find any.
What does axle binding sound like? Anyone else with DSS 0's have binding problems? Thanks
Old Jul 8, 2011 | 11:38 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Axle Binding
did you remove the dust rings from inside the knuckles?
Old Jul 9, 2011 | 07:17 AM
k20rex's Avatar
my k20a crx was do the same thing when turn it would shake really bad, i fix the problem by pulling my front wheels really far foward with my k-tuned traction bar, to get a better axle angle, i also had to lift my car up becasue with my car on the rack i had -1.5 degree even with camber kit, after that i alignment put everything in spec it has been lot better ride since
Old Jul 16, 2011 | 05:00 AM
f20cmx5's Avatar
Yea the car wouldn't even roll with those in
What axles are you running? Do you still have binding problems?
'00_GSR/R
Sep 29, 2010 07:32 AM
fatboy1185
Suspension & Brakes
11
Mar 11, 2010 01:32 PM
88_T-Rex
Feb 3, 2006 09:59 AM
technine
11
Dec 20, 2002 08:42 PM
Fooman
Jun 3, 2002 09:14 PM
