A/C Compressor
Old Jul 7, 2011 | 01:14 PM
rich_one1's Avatar
Default A/C Compressor
why would the A/C compressor blow out liquid from the side. is it because it was over charged with too much freon ? or bad seals ?
Old Jul 7, 2011 | 01:25 PM
pityocamptes's Avatar
Default Re: A/C Compressor
Sounds like seal failure. The entire system is closed so if you see any oil or freon, you have a leak in a seal, or hose. When you mean the "sides" are you talking about the compressor casting itself?
Old Jul 7, 2011 | 01:32 PM
rich_one1's Avatar
yes on the left side of the compressor.... i took off the shield to see where it leaked out of....it just had a fat looking hex bolt with a plug in the middle of it.... so would the problem be that the A/C might have been overcharged ?
Old Jul 7, 2011 | 01:35 PM
Can you take a pic and post it?
Old Jul 7, 2011 | 01:37 PM
Are you talking about where the line goes into the compressor?
Old Jul 7, 2011 | 01:39 PM
Did you charge the a/c system? Did you use a manifold gauge to see the pressure on the high and low side while charging?
Old Jul 7, 2011 | 01:46 PM
rich_one1's Avatar
i put a tack on the picture to point out where the compressor was leaking out of.. i took the picture from the top of the car not the front so in the picture the front bumper would be at the top of the picture and at the bottom right is the header
Old Jul 7, 2011 | 01:49 PM
rich_one1's Avatar
in your picture i can see a thin metal plate on the compressor on the side by the header, it was leaking from underneath that, so i took off that plate that was held on by 3 10mm screws and under it shows that big fat hex nut
Old Jul 7, 2011 | 03:52 PM
Former User's Avatar
High-pressure relief valve
Many systems incorporate a high-pressure relief valve as a safety device
in the event that pressure inside the system exceeds safe levels. (Some systems
use a disc instead of a valve; when a predetermined pressure is
reached, the disc will burst.) Most pressure relief valves will close when the
system pressure has returned to a safe level. Excessive pressure can be
caused by an overheated condenser or an overcharge of refrigerant.
The high-pressure relief valve is usually located on the receiverldrier (expansion
valve type systems) or on the compressor. It's usually mounted in a
safe place so that there's no risk of refrigerant being discharged toward anyone
working on the vehicle.
If the high-pressure relief valve opens for any reason, the system will require
recharging with refrigerant and compressor oil.
Old Jul 7, 2011 | 04:15 PM
motegicivic's Avatar
Another way to know if it overcharged if the compressor constantly kicks on and off.
Old Jul 7, 2011 | 05:38 PM
rich_one1's Avatar
thanx for the help....
so what would be my next step ? should i just go ahead and get it recharged with freon and how would i add oil in the compressor
Old Jul 7, 2011 | 06:05 PM
maxboost10's Avatar
I had the same problem. My expansion valve was marginal and my condenser was very marginal. I now have new expansion valve and new lower mileage condenser (not sure how much). My compressor is on its last leg with 350k on the clock. I have in the works a conversion to a 95 setup with lower mileage but will prob gets some parts new.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/c-leak-much-pressure-2790980/
Old Jul 8, 2011 | 07:30 AM
https://honda-tech.com/forums/showthread.php?t=2790980
I am surprised you still have the compressor with much mileage, if you get a new copmpressor it will be night and day.
SW20FL
Jun 25, 2015 04:47 AM
marqoid
10
Jun 28, 2013 04:41 PM
jasrams
Honda Civic (2001 - 2005)
Apr 23, 2012 08:59 AM
curtie94
Jul 24, 2011 01:34 PM
M@
Mar 31, 2007 10:14 AM
