Suspension & Brakes Theory, alignment, spring rates....
sway bar question
Old Jul 7, 2011 | 12:11 PM
sh!ft's Avatar
Who the fack changed my title?!
Default sway bar question
besides the itr, which sway bar(s) are the best in stock for for an ef hatch that will not affect alignment or camber or excessive wear on the bushings??
Old Jul 7, 2011 | 12:44 PM
GagnarTheUnruly's Avatar
Default Re: sway bar question
Any swaybar that you can get to fit should work fine without causing extra wear. They don't really do anything other than change your effective spring rates during cornering, and they don't bear a load when idle so they won't affect suspension geometry at all.
Don't ASR/ITR bolt more or less straight onto EFs?
Old Jul 7, 2011 | 12:55 PM
Libertariat's Avatar
Ek Forever y0!
Swaybars couldn't possibly affect alignment. Only if the LCAs or some bushing you replace is replacing a totally destroyed bushing.
None of them cause excessive wear on anything besides the endlinks they're in.
sh!ft's Avatar
not so sure. but i did see an asr for sale on here so i might pick it up
Old Jul 8, 2011 | 03:32 PM
gofastgokart99's Avatar
They call me the part of a womans vagina that causes pleasure.
not trying to thread jack but I am currently installing an ASR subframe brace/24mm sway bar combo on the rear, with adjustable endlinks...does anyone have the same set up or something similar on their integra/civic/del sol? I am using function % form LCAs if that makes a difference.
If so could you post them or PM them to me please...i just wanna make sure i am doing this correctly.
Old Jul 8, 2011 | 05:32 PM
90_EX_Civic's Avatar
ASR/ITR combo yes.
but op, if you have a EF, you should find a sway bar that mounts like a oem type sway bar. imop
K20egcw
Suspension & Brakes
14
Sep 5, 2012 07:59 PM
zippo1130
15
Jan 15, 2008 07:45 PM
MaaseyRacer
Aug 17, 2004 09:40 PM
sol2nr
10
Feb 17, 2004 06:29 PM
cxSOHChatch
Aug 19, 2002 05:31 PM
