Lost of oil and sometimes coolant?
Old Jul 6, 2011 | 08:17 PM
tundra2000's Avatar
Default Lost of oil and sometimes coolant?
I got a 95 civic hatch with b20 turbo swap, once and awhile i will have a lost of coolant (not much) and i have to add about a quarts or two of oil about once a month, is this normal for a turbo motor? from what i seen their hasn't been any smoke coming out of the exhaust.
Old Jul 6, 2011 | 08:30 PM
civickiller's Avatar
Default Re: Lost of oil and sometimes coolant?
2 quarts a month. thats alot
hows the blowby?
i never saw smoke on mine till i opened it up
Old Jul 7, 2011 | 04:55 AM
VTC_CiViC's Avatar
Oil consumption, to a degree, is expected on a boosted application. Loss of coolant is another story. Cylinder leak down test might be a good idea, or at the very least pressurize the cylinders and check for coolant bubbles indicating a headgasket seal concern.
Old Jul 7, 2011 | 09:57 AM
tundra2000's Avatar
i'v pulled the piping off before and their was at least a layer of oil on all the pipes
Old Jul 7, 2011 | 01:24 PM
my motor smokes more than a burnout, i only lose about 1 quart a month. unless you open it up all the time
sounds like turbo seals leaking oil
Old Jul 7, 2011 | 01:25 PM
VTC_CiViC's Avatar
Again to a degree, normal. Factory PCV system wasn't designed to handle pressure, i'd usually have a very light film of oil on the inside of some pipes after a few months.
Old Jul 7, 2011 | 01:57 PM
but that doesnt explain oil in the charge pipes or am i missing something ?
Old Jul 7, 2011 | 05:50 PM
VTC_CiViC's Avatar
If the stock pcv system is still in use, there's likley a little oil being drawn into the intake/charge piping somewhere, you also have to account for some oil loss at the compressor/center section seal which I think you already pointed out.
Old Jul 7, 2011 | 06:44 PM
pcv can explain oil in the intake mani but not the charge pipes.
oil in the charge pipes is either the turbo seals or the motor itself
i say just take off the turbo mani and see if the exhaust ports have oil in them. then youll know if its before or after
IMHARD2
Aug 5, 2008 03:17 PM
welfarepc
Jan 10, 2007 10:26 AM
bdavis
Feb 20, 2006 01:16 PM
311
Jul 13, 2004 11:54 AM
hybridb18
Aug 6, 2003 09:00 PM
