pcv valve, and or running problem
Old Jul 6, 2011 | 06:08 PM
ekjdm89's Avatar
Icon6 pcv valve, and or running problem
Well I have changed ma pcv valve, my fuel filter, spark plugs, wires, distributor cap and rotor pretty much a full tune-up besides the oil change since I don't need dat yet. But every once in a while I go to start up ma car, and it acts as its running on 3 cylinders in a way for only a matter of about 10 seconds, and I step on da gas and it goes away. Now I have added fuel system cleaner made by lucas, since I do work at autozone. Just tryin to figure out this problem. Cuz it acts as a miss fire. Any suggestions?
Old Jul 6, 2011 | 06:30 PM
Slacker93eg's Avatar
10 Year Member
Default Re: pcv valve, and or running problem
SeaFoam the **** out of it. Love that stuff
Old Jul 6, 2011 | 07:01 PM
95EG2's Avatar
make sure plugs where properly gapped
Old Jul 6, 2011 | 07:07 PM
that_boy_sammy's Avatar
Not so much at once you'll hydro-lock your junk. Do it gradually. Injectors might be durrty.
Old Jul 6, 2011 | 07:14 PM
hyperblu's Avatar
Lucas =
Old Jul 6, 2011 | 07:41 PM
ekjdm89's Avatar
Well I already used the lucas and its seems like it hasn't done anything for me at all. The spark plugs are gapped, and I am sure they came pre gapped since there NGK Platinum. But I will try the seafoam when I do ma oil change in like 700 miles. Or should I do it now?
Old Jul 6, 2011 | 07:48 PM
10 Year Member
Of course not all at once. I use it in a controlled dripper thing we have at work, it drips very slowly into the intake manifold via brake booster line, and it takes about 30-45 minutes. Once your done rev the motor up and watch the smoke screen. It's the most effective way to do it
Former User's Avatar
Is this a low idle or misfire problem?
Old Jul 7, 2011 | 03:23 AM
ekjdm89's Avatar
ya its still idleing kinda low also, ans it misfires evry once in a while. And wouldn't u be able to put da seafoam into the gas tank and jus let it run through the whole system?
Old Jul 7, 2011 | 06:03 AM
cjk95delsolsi's Avatar
Since you replaced your plug wires you should check to make sure that they are seated in all the way in the dizzy cap and on the plugs on the valve cover. Sometimes they can pop off when you replace new ones, happened to me on several occasions. I would also check your timing.
Old Jul 7, 2011 | 01:55 PM
ekjdm89's Avatar
well everything seems like its fine now since it hasn't happend in a couple of days but how would the timing have to do wit anything?
spens 91 Ef
May 28, 2009 05:56 PM
yarara0825
Jan 4, 2008 04:44 PM
Trumpster
Oct 30, 2004 03:24 PM
