5 speed only shifts with engine off?!
Old Jul 5, 2011 | 04:58 PM
Samwilt's Avatar
Default 5 speed only shifts with engine off?!
I'm having this same problem with my 93 accord lx after I had a new clutch. I replaced the master and the slave. Blead it and I can't het the pedal where I want it but the slave is moving and if you look in the inspection hole you can see the pressure plate moving. But it won't go in to gear. It goes into gear with the motor off all day long. But when you start it it won't go into gear. It's got me mad stumped. Can some one help? Lol
Old Jul 5, 2011 | 05:19 PM
AndyD's Avatar
Default Re: 5 speed only shifts with engine off?!
I had this problem when my clutch disk warped due to the spring popping out of the clutch disk.
Try this....WITHOUT ANYTHING IN FRONT OF YOU!! While the car is off, put the car in first, push the clutch in, and try to start it. Does the car move forward as its trying to start?
Old Jul 5, 2011 | 06:07 PM
SQ is the SQUAD's Avatar
clutch is gone
Old Jul 5, 2011 | 10:41 PM
placid888's Avatar
Originally Posted by SQ is the SQUAD
clutch is gone
sounds like it, but he had a new clutch
Old Jul 6, 2011 | 04:12 AM
is the clutch disc in the correct way? it may be defective, or the wrong one
Always262
Transmission & Drivetrain
Jun 25, 2017 07:16 PM
Duck55
Mar 2, 2010 05:49 PM
sr_teggy
Mar 18, 2007 03:26 PM
hellrsnCL
Aug 10, 2005 08:29 AM
esoterEK..
Oct 5, 2003 10:26 AM
