Running a nonchipped p28 with b16a2 eg swap
Old Jul 5, 2011 | 02:51 PM
Mad-Mike's Avatar
Default Running a nonchipped p28 with b16a2 eg swap
Can I run my 94 civic cx with b16a2 swap with a nonchipped p28? I know it will have a rev limit but will the car drive around and idle normally without any problems? I don't have enough to get it chipped yet.
Old Jul 5, 2011 | 03:20 PM
that_boy_sammy's Avatar
Default Re: Running a nonchipped p28 with b16a2 eg swap
I would use a b16 ecu. Just get a p30 or even p72, P2T will work also. You might run into some problems with a p28.
Old Jul 5, 2011 | 03:32 PM
tlarimer's Avatar
will it run....Yes
Is it advisable.....NO
But hey it's your engine and $$$$$
JDM OBD1 P30 ECU's are fairly inexpensive and is the right ecu for your chassis, assuming you used a OBD1 or OBD2 integra engine harness, since you want to run a P28, it's safe to say you stayed OBD1
Old Jul 5, 2011 | 03:41 PM
Mad-Mike's Avatar
I'm using a obd2 integra harness. Right now I'm running with a p75 ecu.
Old Jul 5, 2011 | 03:52 PM
tlarimer's Avatar
In my opinion, I wouldn't run the engine/car with the wrong ecu. Just wait until you can get the proper ecu or a chip with P30 maps. But that's my .02 cents worth
Old Jul 7, 2011 | 06:54 AM
rhymeshark916's Avatar
To socket and chip a Vtec Ecu is around $50-$70 dollars. Non-Vtec add $50 more. He burn you a base map with basic bolt-ons,
boostedjdmdc2
12
Mar 7, 2008 10:09 PM
redefsir
16
Jun 13, 2007 11:38 AM
egboostin6
Mar 20, 2007 12:28 PM
dthug
Mar 26, 2006 06:15 PM
hYbRid_Eg6
Jul 31, 2005 09:36 PM
