intake?
Old Jul 5, 2011 | 11:20 AM
CanadianEF9's Avatar
Default intake?
all you guys with b series motors in their ef's and still have their battery in their factory placement what did you do for an intake? i just had a filter on my intake manifold and dont like it and dont know what to try so what you got?
Old Jul 8, 2011 | 11:42 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: intake?
AEM makes intakes that fit well with a swap. Their quality is really high as well, so i would say they are almost worth the money.
Otherwise, most of the ebay intakes will likely work, just don't use the filter that those kits come with because they are usually junk.
Old Jul 9, 2011 | 05:07 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: intake?
Exactly - I use AEM intakes... at least until I turbo it... I keep one laying around just so I can use it for a short time to check out the swap/ built motor. :smiley:
Old Jul 9, 2011 | 07:44 AM
nineohnine's Avatar
Default Re: intake?
i went to napa (a few years ago) and bought an off the shelf intake labeled for a 93 Integra. The bends where perfect only downside was it was too long. i had to cut like a 6-8in strait peice out of the middle section and bought a 3in-3in coupler. The coupler was in the perfect spot to insulate the pipe to protect it from a battery short. all in all the whole setup cost me 67.99 from a local part store and about 20 mins of my time to make it fit right.
this pic is from like 4 years ago.
note: does work with a b series i later swapped in a b18a1 and needed no modifications to the intake.
Old Jul 9, 2011 | 08:48 AM
crx_si-r's Avatar
Default Re: intake?
Screw the AEM intake, I got rid of mine in favor of an actual OEM EE8 (EF8 UK model with B16). It's Beefier and I prefer the oem look. I feel no difference with this intake compared to the AEM.
Old Jul 9, 2011 | 11:28 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: intake?
Ebay one will fit with some trimming or, make your own it's rather simple only need some 3" pipe and measuring you can buy mandril bent pipe for quite cheap.
SiK20A3
27
Oct 19, 2012 07:18 PM
potatostix
Oct 14, 2009 03:55 PM
toshko321
10
Feb 6, 2009 11:49 AM
alky350
Sep 20, 2005 07:32 PM
whiteknightef
May 10, 2005 11:05 PM
