97 accord V6 CEL 8 and 9
Old Jul 5, 2011 | 11:17 AM
civic95hbvtec's Avatar
Default 97 accord V6 CEL 8 and 9
https://honda-tech.com/forums/honda-accord-1990-2002-2/check-engine-light-codes-cel-diagnostic-trouble-codes-dtc-malfunction-indicator-light-mil-1490107/
This says code 9 is not valid for v6 ? but it throws it...
Crank angle sensor--- http://www.ff-squad.com/technet/ckftrick.htm
I would like to do this mod... but my accord harness is way diff at the ECU
Anyone have any info on this ?
Can i get to the TDC sensor without pulling the t-belt cover ?
Old Jul 5, 2011 | 11:46 AM
Default Re: 97 accord V6 CEL 8 and 9
Also is code 8 a cam sensor ?
I was thinking crank angle but that seems like code 4
Old Jul 5, 2011 | 12:08 PM
g-spot's Avatar
well i had the same problem with mine and i went and bought the sensor its only like 190 at the part store
Old Jul 5, 2011 | 03:13 PM
Anyone know where i can download a free repair manual for a 97 accord V6 ? ? ?
I can only find f22 4cyl stuff and thats not helping me at all.
Anyone able to tell me if there is TWO sensors... Crank AND Cam sensors ?
Old Jul 6, 2011 | 12:01 PM
So can anyone tell me if there is a CAM sensor up top ?
Or is there only a crank sensor ?
Old Jul 6, 2011 | 04:13 PM
justinsbg's Avatar
On the V6 there is all three sensors. There is a combo sensor (TDC/CYP sensor assembly) behind the front camshaft, the crank sensor picks up off the crank pulley. These sensors are behind the timing covers. The connector for the TDC/CYP is attached to the oil dipstick tube and the crank sensor connector is near the oil filter housing. I'm not very familar with single digit codes on OBD2 vehicles. Do you know what the 4 digit codes are ex.."P1362"?
Old Jul 7, 2011 | 01:28 AM
8 TDC Sensor (Top Dead Center) defective circuit or unplugged / defective sensor
9 CYP Sensor (Cylinder) defective circuit or unplugged / defective sensor
I dont have a code reader so i have to use the check engine blink method.
those are the codes, Sound like its not the crank sensor right ?
Old Jul 7, 2011 | 03:39 AM
justinsbg's Avatar
Nope, I would look into the combo sensor assembly. You can ohm test each sensor. The specs are 1.5-3.0 kohms for each sensor. The red and green wires are for the TDC sensor. I would ohm test the sensors after the engine is hot. If you have a DSO (digital storage oscilloscope) that is best to test the sensors with.
Old Jul 7, 2011 | 10:25 AM
^ Thanks buddy your being super helpfull !
So i have to pull the t-belt cover to get to the combo sensor assembly, and test it correct ? I dont have a DSO but i do have a decent ohm tester.
The sensor at the crank seems like the only one i can get to the plug to test easily.
Old Jul 7, 2011 | 10:34 AM
oh ya, it does only trip the codes after the motors warm, then it pretty much wont run.
Im a d,b,f,h series guy, this is a friends accord im just helping her with, its hard to find info
on this 2.7 V6 everything on Hondatech if F series for accords.
The crank sensor is pretty oily down there, that oil filter is NASTY... but i would think that would through code 4 so im still leaning towards the dual sensors.
Old Jul 7, 2011 | 10:39 AM
justinsbg's Avatar
The connector for the combo sensor is clipped on the oil dip stick tube. It's a 4 pin connector. You can test the sensor there.
Old Jul 7, 2011 | 11:11 AM
OK got ya i found it, ill check back later tonight after i test it.
Thanks buddy !
Old Jul 13, 2011 | 11:12 AM
OK... I tested it, it was bad. Got the new one today.
Now that i have the front cam cover off, i see the sensors... kinda hidden.
Do i have to pull the COMPLETE side cover and t-belt to change this sensor ?
Old Jul 13, 2011 | 12:39 PM
Nevermind... I carefully just slid the cam gear off, with the belt, swapped the sensor
re-checked timeing all looks good.
Battery died so after its charged ill give it a go.
Old Jul 13, 2011 | 02:56 PM
justinsbg's Avatar
Sorry I haven't spent much time on here lately. Work is crazy. Glad to hear you found the problem. keep me posted on how things turn out. Blessings.
Old Jul 15, 2011 | 10:36 PM
2 days later the code is back, 8 and 9... brand new sensor so thats not it.
Ok pretty stumped... Could dirty points on the cap and rotor cause a missfire that
trips up the cam/tdc sensor ? I know on 4cyl these sensors are in the dizzy.
What else could be connected to that sensor ?
Old Jul 16, 2011 | 03:50 AM
justinsbg's Avatar
Ok, this is rare but I have seen diode ripple cause electrical interference with pick up sensors but it usually would occur a lot quicker than 2 days. You could try to run the vehicle with the alternator unplugged for a while to see if the problem returns. Did you check to see if there problems with the wires going from the connector to the ECM?
Old Jul 16, 2011 | 12:43 PM
Whats a good way to check from connector to ECM ?
Ive had that prob with alts before also, but ya this problem takes a little time
to show its self, makes test driving it hard because i dont want to get stranded.
Old Jul 16, 2011 | 04:05 PM
justinsbg's Avatar
A wiring issue is far reaching because for the most part Honda wiring is pretty stout. If it were a wiring problem I would suspect the problem would show quicker. Was there any cruddy green build up on the harness side connector? So why did you replace the combo sensor assembly? What was the resistance of each sensor? Where did you get your sensor assembly?
Old Jul 16, 2011 | 05:17 PM
I dont think its wiring either, its bone stock pretty clean car.
Sensor had no crud build up, I replaced the combo assembly because the owner
was in a huge rush, and had the cash $320... It worked for 2 days then she left work
cold motor and it tripped code 8 and 9 again. SO im cleaning and returning the new sensor and putting back on the old one, get her money back. (these sensors dont go bad often stupid move on my part)
New sensor is OEM Honda.
Im using a Digital Multi Meter set on ohms 20k and it says 9.55 and climes down
slow never stopping into -001 ect. I honestly only know how to check volts, continuity... Trying to read the resistance im un-sure of. Really dont matter now that i used a new sensor, its not the problem.
You dont think a simple problem like dirty cap and rotor could cause it ?
Old Jul 18, 2011 | 05:46 AM
justinsbg's Avatar
I just saw a service bulletin concerning the codes you're getting. For some reason the bulletin is saying that if you get both of those codes at the same time to replace the Crankshaft position sensor even though the codes aren't related to the Crank sensor. How about measuring resistance of the Crank sensor? Post a pic of your meter and let me see what settings you have and I'll let you know how to hook up.
Old Jul 18, 2011 | 09:56 AM
There she be... Thanks for all the help buddy, really wanna get this car done.
Old Jul 18, 2011 | 09:59 AM
Also the crank sensor, is pretty nasty looking, oily dirty ect ect Cam sensor was
pretty clean. Im gonna change out the cam sensor for stock again tomorrow, return
the new one and exchange it for the crank sensor.
Old Jul 19, 2011 | 05:51 AM
justinsbg's Avatar
You had it on the right setting. Put it on 20k ohm and before you do any testing touch your meter leads together and see what reading you have. Put one meter lead on one sensor connector terminal and the other meter lead on the other sensor terminal. You should get a stablized reading. Let me know what you get. Take pictures if you want and let me see what exactly you get.
Old Jul 22, 2011 | 12:00 PM
Pretty sure i found it... Pulled it apart and the crank angle sensor has a crack
in the plastic holding the metal part of the sensor. So i bet it vibrates and trips
up the tdc-cam position sensor some how.
Im gonna install a new crank angle tomorrow.
