Converting from B16A to B20/Vtec
Old Jul 4, 2011 | 06:02 PM
1991civicb16's Avatar
Default Converting from B16A to B20/Vtec
Hello all, and thank for looking. I am curious about going from my B16A Swap that is in my Ef civic. The car is running an OBD 1 P28 ecu, ODB 1 Dizzy. My question is will i need to do any changes to the wiring if im using my current B16 head on the B20 as well as the IM and Throttle body. Any help would be appreciated thanks!
Old Jul 4, 2011 | 06:14 PM
crx_si-r's Avatar
Default Re: Converting from B16A to B20/Vtec
Nope. Slap on the head (do the needed b20vtec conversion of course), and your good to go.
Old Jul 4, 2011 | 06:30 PM
Thats what i figured but wanted to double check thanks for the help i really appreciate it.
Old Jul 4, 2011 | 06:32 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
x2 million
Old Jul 4, 2011 | 06:54 PM
.Manny.'s Avatar
Touching My Member
Post results when you're done. You'll be very pleased with the difference. Stock block?
Old Jul 4, 2011 | 07:01 PM
Nope, going to keep stock bore but i will be running some Cp pistons(11:5:1) with Eagle Conneting rods. Polish and balance crank. Mild Port and polished B16 head with skunk 2 valve-train, and a Skunk 2 Tuner stage 3 cam B16A IM with B16 throttle body both port matched. Hoping for some good numbers...
Old Jul 4, 2011 | 07:15 PM
.Manny.'s Avatar
Touching My Member
Very nice. Just make sure your clearances are spot on and longevity won't be an issue.
Old Jul 4, 2011 | 07:26 PM
Having all the work done by a machine shop so hoping they do it all right lol. I will post the Tuning info when i get it back from the shop.
wils92sedan
11
Dec 25, 2011 05:58 PM
Driven
Jul 9, 2010 04:39 PM
cbabyby
Aug 22, 2006 02:48 PM
Pandahatch
May 1, 2004 05:04 PM
