after motor swap engine wont start
Old Jul 4, 2011 | 11:01 AM
1998typesh's Avatar
Icon2 after motor swap engine wont start
hi guys, i recently finished a long project of swapping a jdm h22a with m2b4 trans into my 98 type sh. It cranks over and i can smell fuel. i believe it is not getting spark. On the original motor i had a crane ign system and a vafc. both of which I have unhooked setting the car back to stock. What am I missing?? I do have a couple connectors that are not connected, but only because there are no connectors to connect to.
I do have an obd1 computer with the correct harness.
any help is gratefully accepted
thanks
Old Jul 4, 2011 | 11:19 AM
asianpoet's Avatar
Default Re: after motor swap engine wont start
is the jdm motor obd2 or 1?
if the motor is obd1... you would have to swap the oil pump.. which has the holes for the connector that goes behind the crank gear..
or option 2:
run some wires to the cfk, (or is it cpk) to the distributor... (which you would need a 92-96 distributor model td61u) that has the sensor within it.
Pm me if your interested in these items... since i have them both..
I did these same swap, to get my car running. passed smog, with no problem.. at least in vegas.. however i'm building a g23 motor and i have since converted it back to obd2
Old Jul 4, 2011 | 12:10 PM
1998typesh's Avatar
yeah the motor is obd1, from a 1994 jdm h22a.
Dont quite remember having a loose connecter near the crank pulley, do you have any pics?
Old Jul 4, 2011 | 02:09 PM
1998typesh's Avatar
here is a pic of the few connectors that dont seem to match up
number 1 has a plug in it and when removed it will connect to number 2. not sure if i should connect these though
number 3 and number 4 are the same size/type of plug except for color, 3 is grey, 4 is green.
any one know what these are?
thanks.
Old Jul 4, 2011 | 05:54 PM
asianpoet's Avatar
http://www.hondaautomotiveparts.com/...-+OIL+STRAINER
item number 21
picture number 2. If im not mistaken is the sh transmission conncector..
Old Jul 4, 2011 | 06:06 PM
asianpoet's Avatar
private message.... sent...
Old Jul 5, 2011 | 04:20 AM
nus_dogg's Avatar
Just notice you posted this on SHO as well.
Old Jul 5, 2011 | 05:05 AM
1998typesh's Avatar
yeah trying to reach the most people as i can.
Old Jul 6, 2011 | 05:51 PM
asianpoet's Avatar
forgot to ask... but did you swap the intake manifold... from the old motor to the jdm motor?
pimpdd101
Dec 28, 2018 02:24 PM
H22palms
Jul 29, 2012 08:28 AM
Markis.
May 30, 2009 06:08 PM
Dragline
Nov 13, 2004 06:29 AM
