need help with vtec pressure switch wiring on h22
trying to wrap up wiring on my first h22 swap in cb7 accord. the h22 did not come with harness, using my accord harness adding the wires needed but the h22 did not have connector on the vtec pressure switch so i got another from a junkyard but its not same colors. it has black and green leads. anyone know witch pin goes to ecu and witch is ground? i only have wiring schematic for cb7. thanks for any help.
Top pin on the switch is the power source - (coloured wire) - VTEC ECU pin D6.
Bottom pin on the switch is ground source - (BLK) - to ECU pin A26. (or spliced into the BRN/BLK wire that should already be in A26)
Dont mind me. Im just bored at work on the 4th of July with nothing else to do.
