Car Dies Randomly
I have a eg coupe, complety stock, it will die randomly for no reason
, If im on the E-Way an put it into neutral just to coast an save gas the car will just die suddenly. Also if im doing about 55 an come to stop(not a sudden stop) but at a stop light it will just die. It doesnt have any problems starting or anything. If anyone could help me with what this could be it would be much appreciated.
could be a pvc valve or cam positioning sensor. For the pcv valve replacement check here for the how to's if you dont know how.
http://www.clubcivic.com/board/showthread.php?t=68638
Sounds more like a pcv problem. Also if that is the problem check your air filter for blow by. Try that first very simple if you cant tell.
For the cam positioning sensor it can be tricky. If you want to do it your self get a Haynes or Chiltons manual. Which ever you prefer.
It sounds like what my Accord was doing when my main relay was going out. Click it into the on position and listen for the fuel pump priming under the back seats. If it doesn't always buzz, check the main relay. It's a grey box near where you put your left foot, and it controls the fuel pump and FI. They're known to go out. It looks for the most part like this:
civicb16eg
Jul 18, 2007 06:15 PM
b16gurl
Jan 30, 2006 02:00 PM
