opinions needed!
Old Jul 3, 2011 | 08:21 PM
beastinisgr8's Avatar
Default opinions needed!
I have a stock ls I was going to run low boost on but I came across this.
b18a1 block bored to 81.25mm by jackson racing
(brand p72 crankshaft(gsr)
p72 rods(gsr)
p73-a0 pistons 81.25mm(usdm type r)
honda piston rings
king race bearing rods and main and thrust washers
stock oilpan
stock windage tray
new timing belt stock b18b head with around 45k miles
Compression calc. Says 10:3.1
I think this ran with a simple turbo kit.
T3/4 hybrid turbo
800cc injectors
Arp head bolts
Walbro 255
I'm only looking for 325 reliable hp.
Opinions and suggestions welcome!
Old Jul 4, 2011 | 04:18 AM
SLIM NOTHING's Avatar
Default Re: opinions needed!
build your own.. feel proud that you built your own.. if oyu build your own then you you will know if something is wrong and can fix it before messing things up. you dont know what is wrong with that motor. not saying its bad, but you never know.
subman20
Oct 9, 2013 07:55 PM
Nisif
Aug 30, 2012 09:55 AM
nealnanoHX
Mar 23, 2012 04:29 PM
honura
May 9, 2009 09:34 PM
GEN2 LS
Oct 11, 2007 07:32 AM
