B series swap. Is it worth it?
Old Jul 3, 2011 | 06:16 PM
boostedef123's Avatar
Default B series swap. Is it worth it?
Im planning on doing a EG hatch build when I get the money and find a good shell to use. What im planning on doing is either a D16Y8 boosted. Or a B series boosted. But what im wondering is there that big of a performance difference in the two motors. Besides of course the dual cams. Is it just a 40-50 hp diff. Or would it make in the end a huge 100 hp diff after building it. Also Im guessing D series are also cheaper to build rather and a B.
Old Jul 3, 2011 | 07:02 PM
FlewByU352's Avatar
Default Re: B series swap. Is it worth it?
B series has more room for improvement and much better transmissions. The longest B series trans is the shortest D series trans. Also with the D series the ridiculously unequal axles makes for some terrible torque steer.
Old Jul 4, 2011 | 03:06 AM
grumblemarc's Avatar
The Grumpiest
Worth it? What are the criteria? Time? Money? Experience?
God I hate these open ended questions.
Old Jul 4, 2011 | 08:48 AM
Time money and experience is not what im worried about. Im worried about the actual end result from it. Would losing all my accessories just to put in a bigger motor and a turbo be worth it or just stick a D series like it was made for.
Old Jul 4, 2011 | 08:52 AM
96electronH's Avatar
you dont have to lose ac or ps and i wouldnt turn back doing a bseries swap im about to boost it now and glad its not a d series anymore.
Old Jul 4, 2011 | 09:02 AM
The Grumpiest
Where do you lose anything when doing a swap? A B16 came stock in the SI. It has all the accessories the EX does. Don't understand where you're getting this from.
Old Jul 4, 2011 | 10:33 AM
I Didn't know that. I miss assumed. When you do a swap do you have to pull the wire and re run them for the new motor or can you get adapters for the ecu plug etc. I`ve never attempted a EFI swap so no idea about the computer control area of it.
Old Jul 4, 2011 | 12:38 PM
that_boy_sammy's Avatar
I don't think you would have to re run any wires. if its an obd1 motor it will work perfect. Since the d16y8 is obd2 your going to have to get a jumper harness.
Old Jul 8, 2011 | 12:46 PM
What do jumper harnesses run.
Old Jul 8, 2011 | 04:19 PM
SJC's Avatar
SJC
if your not worried about money swap in a K and boost it.
dacaveman
26
Jul 2, 2003 08:33 AM
