Del sol wiring problem!! please help!!
Old Jul 3, 2011 | 03:01 PM
please_hop_off's Avatar
Default Del sol wiring problem!! please help!!
hello ht.... im having a problem where my ecu is not powering up... also the check engine light and the seat belt light not coming on.... i do have the ground wire on the tranny to the frame... i also have the ground wire on the themostat... fuse is good and the main relay is good.... please help thanks
Old Jul 3, 2011 | 03:03 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Del sol wiring problem!! please help!!
A little back story might help diagnose the issue. When did it start happening? Did you try a known working ECU?
Old Jul 3, 2011 | 03:07 PM
yea i tryed and known ecu
Old Jul 3, 2011 | 03:11 PM
The Grumpiest
Do people only read the last sentence in a post?
When did it start happening? Were you doing any work to it? What?
Old Jul 3, 2011 | 03:14 PM
well i got a new shell and got rid of the other shell that the swap came out of and put it in the new shell... and the new shell was running before bought...
Old Jul 3, 2011 | 03:54 PM
Hodahustle's Avatar
How's the charge you try boosting it
Old Jul 3, 2011 | 04:20 PM
The Grumpiest
What? Is this English?
Old Jul 5, 2011 | 09:28 AM
no help???? i put a obd1 motor in obd2 car with jumper harness to p06 with hondata... and the ecu didnt light up (hondata box s200) so i start researching for wire color ecu write up pin out and pulled all the pins out of the connetors and put the power wires and ground wire back in the connetors to see if it works and it does..... after that i start messing around... and now the cluster n windows and the ecu dont work.... all the fuse is still good please help me where to start thanks
Old Jul 5, 2011 | 09:38 AM
The Grumpiest
So essentially you re-wired up your ECU/harness wrong, because the Hondata box didn't light up, and you're wondering what the problem is?
Do you know how to put everything back the way it's SUPPOSED to be?
I wonder how you thought someone was supposed to help you without this information up front.
Old Jul 5, 2011 | 09:44 AM
yes i was wondering what was the problem was... and the obd2a pin out is little bit off by the color since its a del sol... and yes i understand that info up front was not enough info...
cjordan
Engine Management and Tuning
Apr 1, 2012 02:13 AM
silverbur
Feb 5, 2008 01:42 PM
HamiltonRex
Jul 10, 2004 01:05 PM
REWURKD
Apr 8, 2004 08:54 PM
Tinker219
Sep 20, 2003 04:53 AM
