Bleed the cooling system question
Old Jul 3, 2011 | 10:52 AM
motegicivic's Avatar
Default Bleed the cooling system question
I just bleed my cooling system, and towards the end of say 25 mins, it spilled some coolant out the neck, is that normal?
After I had to add quite a bit of coolant, where does the coolant go if there were no leaks and the neck was full at the start of the bleed?
Old Jul 3, 2011 | 10:57 AM
bluejcivic's Avatar
Default Re: Bleed the cooling system question
you still have a bubble in the system, just top it up over the next couple of days and you should be fine
Old Jul 3, 2011 | 11:01 AM
Golden Eagle's Avatar
That could have just been the final burp of an air bubble caught in the system when your thermostan opened at temp.
Old Jul 3, 2011 | 11:02 AM
How do I know if I still have air?
The blurp of coolant through the neck meant there was air blurping out?
Old Jul 3, 2011 | 11:25 AM
hyperblu's Avatar
Yes. Air behind it pushed it out, or you have too much coolant...
Old Jul 4, 2011 | 05:51 AM
that_boy_sammy's Avatar
The bleeding process of the coolant system IMO is dumb and a long waste of time. Drain the coolant by loosening the t-bolt, then pour it back in and watch for burps. Works way better, takes 10 minutes.
Old Jul 4, 2011 | 07:34 AM
It is not that easy, when you bleed it you run it with heater on, to purge the entire system of air.
Old Jul 4, 2011 | 12:30 PM
It actually is that easy. I just did it last week. You don't actually have to have the heater on just turn it to hot but not actually on. Forget about standing in front of your cooling system and waiting for bubbles for about 30 minutes . 10 mins Drain,Refill,Burrrrrp.Done.
Old Jul 4, 2011 | 12:47 PM
hyperblu's Avatar
our cars have manual heat valves, turn it to heat and it opens the valve... You dont have to run the blower.
Old Jul 4, 2011 | 04:43 PM
Would anything bad happen if I ran the blower too?
Old Jul 4, 2011 | 05:19 PM
75aces's Avatar
You will know if there is still air in the system. Before I bled my coolant, the temp gauge in the cluster shot all the way up. After the air was out of the system, it didn't go past midpoint.
Old Jul 4, 2011 | 05:26 PM
I have have been checking it, orig it was going past half way from time to time at idle say 3/4 up, that is why I bleed it, I know the fan is working so I decided to bleed.
Funny after I bleed it, it seems to start from cold quicker, it always had a slight hesitation to cold start, can this be it can be easier starting now?
Old Jul 4, 2011 | 05:31 PM
75aces's Avatar
Maybe you have a faulty thermostat?
Old Jul 4, 2011 | 05:35 PM
Seems ok for the last few days after bleeding, if it had a bad thermostat wouldn't it go say 3/4 way up even when driving?
mlee19841
Honda Civic (2001 - 2005)
May 1, 2015 03:26 PM
speedy108
Jan 10, 2006 03:11 PM
budget
Apr 27, 2005 06:02 AM
fe519
Apr 30, 2003 01:30 PM
1.8T_EG
Oct 28, 2002 04:17 PM
