Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2008 civic si foglights
Old Jul 2, 2011 | 08:15 PM
Acharity29's Avatar
Default 2008 civic si foglights
Do the regular civic foglights fit for the civic si coupe?! Im not sure witch set of fogs i have... Cut the hole for the bumper but when i tried to put the foglights on they dont mount on right & theres a big gap in between the plastic & foglight :/
These are the sets i have...
dont have pics of the gap or mounting yet
Old Jul 3, 2011 | 01:57 PM
vladd's Avatar
Default Re: 2008 civic si foglights
The front bumper and foglights are the same between si and non-si coupes.
I'm guessing your foglights aren't OEM? That's probably the issue.
Old Jul 3, 2011 | 04:11 PM
Acharity29's Avatar
Thats what i was thinkin
Old Jul 9, 2011 | 10:59 AM
08siCIVIC's Avatar
I bought a pair of yellow Fog lights from PWJDM and had them installed 6 to 12 months ago. I had to disconnect the battery yesterday to move it so I could change the driving lights out. I wanted different bulbs than stock. After I reconnected the battery I saw that my fog lights no longer work. The light on the dash still says they are on. Anyone have any thoughts. I think maybe a fuse might have went out when I was moving the battery.
Old Jul 11, 2011 | 05:30 PM
jaydakid86's Avatar
To OP: I bought those same fogs from ebay and what i had to do was switch the brackets off the oem ones and mount those on them and they mounted up perfectly. Hope that helps
Old Jul 19, 2011 | 05:28 AM
tigasTT's Avatar
That's a coupe foggy
Old Jul 21, 2011 | 07:28 AM
bee guz's Avatar
I had to do a little bending of the brackets to get them to line up after I did that they did fit.
I still have the wire set (switches and inside wires) except for the piece that runs from one fog to the other, if anyone needs them.
SiCivicHB1993
Jun 12, 2016 09:03 PM
EM1Guru
114
Nov 20, 2007 07:26 PM
pstereo
Apr 12, 2007 08:26 AM
MaseTeg
Apr 24, 2006 06:21 PM
