S300 - Motorolla 2.5 bar w/ Stock Gsr Basemap?
Old Jul 2, 2011 | 12:09 PM
REDEM1FTW's Avatar
Default S300 - Motorolla 2.5 bar w/ Stock Gsr Basemap?
i recently finished my gsr turbo build and need to break the motor in, I do not have the chargepipe hooked up so it will not build boost. I am running S300 and I have put a stock GSR basemap on the ECU. The car will crank but will die almost immediantly.
Will my Motorolla 2.5 Bar map sensor cause this to happen and is my 2.5 bar compatible with my "stock gsr basemap"? It is set to a "stock map sensor" under the map sensor section of Hondata. Would switching to the 2.5 bar in hondata possibly correct this problem?
im kinda new to map sensor settings so any help is greatly appreciated
thanks,
Josh
Old Jul 2, 2011 | 12:48 PM
mtber's Avatar
Default Re: S300 - Motorolla 2.5 bar w/ Stock Gsr Basemap?
You must change the map sensor settings to what ever map sensor you have installed.
KRWTEK1
May 28, 2007 12:32 AM
NA JDM GSR
Oct 29, 2006 08:38 AM
petergriffen
Jul 16, 2006 11:48 AM
beak
Jul 9, 2006 01:28 PM
CiViC SiR
Jul 7, 2003 02:22 PM
